T98 rear bearing retainer/mount
Old 07-23-2017, 02:02 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
Tom, The T98 is a bolt in replacement for the T9 with the exception of the driveshaft. The driveshaft will need to be shortened about 2". The rear motor mount will line up just fine. If you measure from the centerline of the bolt holes on the transmission foot to the face of the half bell, it will be the same on both transmissions.
Mark
Old 07-23-2017, 04:39 PM
F-1Fred's Avatar
F-1Fred
F-1Fred is offline
I've taken a couple of better photos to verify my transmission is a T59. I also have a picture of the mount, though the numbers are a little tough to read. They appear to be OIT7049. Maybe this can help identify what truck it came from. It is just a matter of curiosity at this point because I have started to fabricate a crossmember to support it. Sorry about the up-side-down photos. Not sure what I did when I attached them.
Old 07-23-2017, 04:40 PM
F-1Fred's Avatar
F-1Fred
F-1Fred is offline
I just realized that this says T59 not T98 which I was convinced it is. Now I am really confused!
Old 07-23-2017, 04:56 PM
49fordv8f4's Avatar
49fordv8f4
That is a 1945-1951 spur gear 4-speed. It is an unsyncronized transmission. Rear bearing retainer/mounts are available for that transmission to use it in an F1.
Mark
Old 07-23-2017, 04:57 PM
F-1Fred's Avatar
F-1Fred
F-1Fred is offline
Thanks Mark! I apologize to all for the confusion. Getting a bit senile i guess.
Old 07-23-2017, 05:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
But I thought the original crossmember is gone? Unless you really want to put up with a non-synchro trans, you have a world of choices available to you. T5, Saginaw, Muncie, other B-W's...
Old 07-23-2017, 06:54 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The T9 / T8 crashbox four speed was an option in the F-1s. If you really want to run one then get the correct rear bearing retainer / rear motor mount to fit the F-1. This part is different from the F-2 and larger rear bearing retainer. Since almost everyone rips these transmissions out of their truck you should be able to get parts at giveaway prices (shipping only). If you truly have no cross member you are a candidate for finding and installing a 49-50 Mercury overdrive transmission....
Old 07-23-2017, 07:01 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
Originally Posted by 49fordv8f4
but I don't believe the T98 was available in an F1, only in F2-F6 trucks
I'm pretty sure the T98 was never an option in the F-2 or F-3. I think it was an option in F-4, F-5, and F-6 behind the 226 and 239 motors. I think it was part of the package you got if you optioned the F-6 with the 254 motor.
Old 07-23-2017, 09:30 PM
pineconeford's Avatar
pineconeford
pineconeford is offline
Knuckle Bandage Sales Rep
Tom, The T98 is a bolt in replacement for the T9 ...... If you measure from the centerline of the bolt holes on the transmission foot to the face of the half bell, it will be the same on both transmissions.
Mark
Mark, you are correct - today I finished re-assembly of the T-98 and took measurements. They are the same.
Tom
Old 07-24-2017, 01:39 AM
F-1Fred's Avatar
F-1Fred
F-1Fred is offline
The centre 16" or so of the original crossmember was cut out by the previous owner. I have a 48 frame that has the crossmember, but rusted very thin. I plan to cut the middle section out of it and weld into what is left of mine and plate the weak sections. So, I guess that when that is done, I will try to find the correct rear bearing retainer/mount for an F1 to use with this 59T transmission that I have.
Old 07-25-2017, 11:50 AM
49fordv8f4's Avatar
49fordv8f4
F-1Fred, I checked this morning and I have a 4-speed with the bearing retainer/mount you need. But, after looking at the transmission, you will need more than just the bearing retainer/mount. I sold the driveshaft yoke from the transmission I have a couple of years ago. You will need the retainer/mount, the yoke and the tailshaft out of the transmission. The tailshaft is different than to one in the 4-speed that you have. I can pull the bearing retainer and tailshaft from the transmission I have for you, but you will still need to find a yoke.
Mark
Old 07-25-2017, 01:32 PM
F-1Fred's Avatar
F-1Fred
F-1Fred is offline
Mark,
Thanks for the offer. However, after digesting the comments from ALBUC F-1, 38 coupe, and others (including my wife behind the scenes), I have been convinced that using my non-synchro spur gear 4 speed is not a good decision. I spoke with Glenn Sanders in Maryland last evening and he believes that he has a synchro top loader 3 speed transmission with correct mount and drive shaft for my truck. So it looks like I am now good-to-go, so to speak.
  #28
Old 07-25-2017, 01:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Good choice! You won't regret it
  #29
Old 07-25-2017, 04:10 PM
49fordv8f4's Avatar
49fordv8f4
That is a good choice. You will be much happier with the 3 speed I'm glad you found what you need.
Mark
ghalperin
15
08-19-2022 06:20 PM
STIHL260
07-24-2018 09:48 AM
ghalperin
WTB - Parts & other
12-22-2016 10:47 PM
38 coupe
13
10-01-2015 08:28 PM
rich51fordtruck
05-22-2006 05:34 PM
Quick Reply: T98 rear bearing retainer/mount
