Torklift's Extended Power: When you need more power - Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Old 07-20-2017, 06:59 PM
Torklift Sheryl's Avatar
Torklift Sheryl
Torklift Sheryl is offline
SPONSOR
Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.Torklift Sheryl has a good reputation on FTE.
Help increase your battery power while camping. A great product to consider is the ExtendedPower battery mount, especially if you are towing with an extension. Equipped with spare batteries and the ExtendedPower, you have the ability to go to camping spots in the desert or mountains without worrying about running out of power.
Bring multiple batteries with you on your trip
ExtendedPower
The ExtendedPower is a universal battery mount for housing extra truck camper batteries while mounted on any hitch receiver extension. It becomes an extension of your truck camper batteries and depending on desired application, can easily recharge via solar panels, generators, converters or your truck’s alternator. By wiring the spare batteries housed on the ExtendedPower, enjoy accessing extra power for your RV and your accessories including lights, stereo, computers, winches and more. The ExtendedPower battery system can be plugged into your factory RV plug†† on the back of your truck to facilitate an automatic charge by your trucks alternator. The extra battery mount allows you to power your accessories without having to turn the truck engine on and wasting valuable fuel.
The ExtendedPower battery tray installs quickly with no drilling† required, simply bolting directly onto your hitch receiver extension. The unique design features a quick release pin allowing the battery mount to easily disconnect for teardown and storage. Each ExtendedPower comes with a group 24 battery box. To adapt directly to your specific truck and trailer application, the battery tray mount is height adjustable. With varying levels of trucks and trailers, simply adjust the battery tray to the appropriate height eliminating any clearance concerns. The ExtendedPower battery mount is backed by our Legendary Lifetime Warranty and proudly made in the USA.
† The ExtendedPower steel tray does not require drilling and there is no drilling required on the extension. The plastic battery box requires drilling.
†† ExtendedPower wire harness not included
Note: The ExtendedPower is able to work with 36”-60” SuperTruss lengths. The SuperTruss uses lateral support safety chains for the ultimate in strength and safety, however the safety chains interfere with the ExtendedPower on SuperTruss Extension lengths of 21”, 24”, 28” and 32”.
ExtendedPower Features
  • Universal applications for all receiver extensions
  • Mount extra batteries to power your truck camper accessories while boondocking
  • Becomes an extension of your RV batteries and recharges via your RV solar panels, generator, converter, alternator, etc.
  • Without turning on your truck engine and wasting fuel, access battery power and stay charged up while using electrical accessories such as lights, stereos, computer and more (Wiring harness sold separately)
  • Designed for all types of batteries
  • Battery mount tray is height adjustable to eliminate clearance issues
  • Lockable to prevent your spare batteries from theft
  • No-drill for an easy install
  • Attaches and detaches quickly for battery service using a quick release pin
  • Legendary Lifetime Warranty
  • Proudly made in the USA
Click here to learn about more about Torklift's products.
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
11-28-2017 05:08 PM
Torklift Sheryl
11-02-2017 04:23 PM
Torklift Sheryl
06-06-2017 07:23 PM
Torklift Sheryl
05-23-2017 05:57 PM
Torklift Sheryl
05-16-2017 04:09 PM
Quick Reply: Torklift's Extended Power: When you need more power
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
