What's the hot ticket on oil these days?
Respectfully I have to disagree. With 338k on my truck and an average distance to the moon of 238k my truck has ALREADY gone to the moon and is almost half way back. So, yeah I want to choose the right oil.
We'll be needin' some oxygen tanks and maybe a booster rocket or two, solar panels for-sure (because you know the FICM does NOT like low voltage). And somethin' fur traction... I say we go for some sort of sand tire set-up, then you are good to go on star-dust, or moon-dust, or space sand (you DO know it is out there!)...
Or just find a CJ oil and we all hope you get back through re-entry and all, uhm, safely...
Scott (your friendly FTE court jester)
Weeee're gonna' have to prep ya' just a skosh better than the oil, there big fella', if ya' plan to go to the moon, now...
Something random, tonight at Wal Mart I checked a bunch of bottles thinking that there might be a connection between bottles with the API CN rating for gas engines not being Ford certified because of the reduced ZDDP levels.... but then Valvoline Max Life Heavy Duty Diesel High Mileage 15W-40 has CK-4 and CN both.... and then says is meets Ford WSS-M2C171-F spec.
So I'm back to pretty much not caring along as it says CJ-4 after CK-4. Except I did buy they last three gallons of Delo 400 LE 5W-40 that's stamped CJ-4
They might just have been the LAST Delo 5w 40 CJ gallons left on planet earth!
Bryan: you don't have a stash of non-melter oil filters hidden away also, do you?? Hummm???! I'm gonna' unfriend you, or unlike you, or, or... Something like that... dammit...
Norm: you get your answer yet on the oil Q?
You hypocritical Bast@rd, you!!! Those were MINE!!! I was all set to drive down to Texas tonight and get them!
Now if I could just find a suitable cheaper alternative to my Baldwin bt8851-mpg filters I'd be stoked. Or even a way to find the "alternative" version of the bt851-mpg because I have two seal versions here and only one approaches sealing on my truck.
Did I say $20 per case? I meant PER Gallon!!
They did have a good stash of SuperTech 15W-40.... the way people throw additive packs into these engines that might not be a bad way to go for $10 a gallon.
I'm stock on the oil capacity/filter. Currently at 168K miles, I've only recently done 2 oil analysis. Both at 5k mile oci. Both came back good from Blackstone. Both times, they recommend that I increase the OCI to 7-8k miles. I'm too 'chicken' to do that though. You may be in a better position to do that.
Some oil manufacturers have gone to a low-phosphorus oil blend in order to be compatible with both diesel and gasoline engines. This is good for large fleets that have both diesel and gas trucks in that they only have to purchase one oil brand. The phosphorus is very bad for the gasoline trucks after-treatment system.
Unfortunately, oil mfg's don't publish zinc and phos levels. In order to know if your oil is truly a low-phos blend, you'd have to send out an oil analysis of your new oil.
That being said, anything on Ford's list shouldn't be a low-phos blend, under the presumption that the increased rate of wear in the overhead on their 6.7L testing was from a low-phos oil.
Rotella T4 is on the list, btw. T6 is not..
Mobil Delvac is on the list also.
I don't run synthetic in my truck ..
#28
#29
i like using Polaris labs. They also report oil oxidation and nitration values. one of the characteristics of the new spec oil is better oxidation. Oxidation is reference for an oil's serviceabilty/life so I'm curious if these values will show any change compared to my historical records. I try to keep mine around 4,000 mikes for the OCI since it spends most of the time towing.
