Fuel Economy
Old 07-21-2017, 09:47 AM
69cj's Avatar
69cj
69cj is offline
69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.69cj has a spectacular reputation.
Originally Posted by Deuce40s View Post
You'll get over 18, no worries. I get the same mileage as the OP.
Guess I got one of those non-magical trucks. Just my luck!
Old 07-21-2017, 10:12 AM
Overkill2's Avatar
Overkill2
Overkill2 is offline
Overkill2 is gaining momentum as a positive member of FTE.
Thanks for the info, Deuce...
I made an hour each way trip (highway) recently and my mileage jumped up from 14 mpg to about 16 on the mileage meter in truck, so I figure once I'm on the road for my annual Kentucky road trip this year ( first road trip w my truck )...I'm shooting for over 16 with just straight highway driving and no city stop and go.
Old 07-21-2017, 12:33 PM
jfralph
jfralph is offline
jfralph is starting off with a positive reputation.
Anyone notice the phenomenon of towing mileage is in the 9-11 range regardless of trailer. I have 6 different trailers/items I tow. The biggest/heaviest is a 31í fiver with a jeep, boat or ATV trailer behind it. I also have a utility trailer that maxes out at 14k, a backhoe trailer with tractor. It doesnít matter which I tow, I get about 10 mpg. I recently had to tow the ATV trailer 300 miles. Half empty, half with a 500# ATV on it. I averaged 10 mpg. I have towed my fiver with jeep attached 1700 miles and averaged the same. I have discussed this with other local 6.7 owners, and they also see similar results. Our conclusion is the truck recognizes the trailer attached and the computer alters some parameter. Letís face it, the ATV trailer I tow with the ATV on it doesnít weigh 1000#ís and has very little wind resistance. Fiver with Jeep is in the 17,000# range with massive wind resistance and rolling resistance. There should be a big difference in mileage. BTW, 16-18 on the hwy is common.
Old 07-21-2017, 02:01 PM
ssunit1's Avatar
ssunit1
ssunit1 is offline
ssunit1 has a good reputation on FTE.ssunit1 has a good reputation on FTE.
Originally Posted by Overkill2 View Post
So these other guys are lying? Just wondering...
I talked to a guy in my area who deleted his 11 and he told me he was getting 18 -19 mpg highway before delete.
I run the numbers and don't use the truck mpg.
For those that are DEF delete 18+mpg is probably realistic with not much of a load cruising at a reasonable speed. Throw in some extended hill climbs and 75 or so mph and / or a regen cycle or 2 then it may be a challenge.
Old 07-21-2017, 02:58 PM
Nipperdog's Avatar
Nipperdog
Nipperdog is offline
Nipperdog is gaining momentum as a positive member of FTE.
I have a 2016 F250 with 3:55 Gears and 22K Mi Finally was able to hit 20mpg on my trip to NY last Week
Old 07-21-2017, 05:54 PM
ruschejj's Avatar
ruschejj
ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
In my experience, if you're traveling on a highway for a long cruise, towing mpg is all about the wind resistance. The weight means very little to these 400hp turbo diesels but the drag coefficient certainly does. I get the same mpg whether towing 6,000 lbs or 16,000. Trailer is shaped the same. Only exception would be an open flatbed or a bass boat.
Old 07-21-2017, 06:33 PM
ssunit1's Avatar
ssunit1
ssunit1 is offline
I have to agree. My first trailer was a 8k TT and I got 10-11ish for the thousand or so miles I had that one. Upgraded to my current 14k 5th wheel and am getting 10-11ish. I tow only in Florida, so far, and its all pretty flatland. Once I get up to speed, 65mph, I see the boost stay around 5-6 lbs consistently. Same for both trailers.
Old 07-21-2017, 06:40 PM
69cj's Avatar
69cj
69cj is offline
That 20 mpg is instant mpg, not average. Now I know how some of these trucks are challenging the Prius's. I may have read it wrong but I know numerous 6.7 owners and none of them average that. If I reset on the highway at the correct time I to can match that.
Old 07-21-2017, 06:58 PM
frito1
frito1 is offline
frito1 is starting off with a positive reputation.
34 fuel ups, 11243 miles tracked, and around 17K miles on the truck. 18.0 mpg. '16 XL 4x4 Crew Cab short bed with 3.31 rear gear. primarily my daily driver 40 mile round trip on two lanes to work and 60 miles round trip on two lanes to the farm. Average speed driven is ~60 mph.
Old 07-21-2017, 08:48 PM
Overkill2's Avatar
Overkill2
That 18/19 mpg was highway driving with the DPF intact. I believe he told 21 or 22 mpg highway with delete. I'll talk to him again and find out. Talked to him the other day and his truck has 90k+ miles. He's talking selling it and getting a 2017...
Old 07-21-2017, 09:24 PM
Overkill2's Avatar
Overkill2
Hey Nipperdog...where in New York did you go?
Old 07-22-2017, 07:11 AM
Nipperdog's Avatar
Nipperdog
I an not counting Idle Time. My unloaded MPG was at 20 or even 21 for several hundred miles down I 95. Never been able to do better than`19 before this trip. That's why I took the picture to prove it to my Ram Drivin Brother.
  #28
Old 07-22-2017, 07:13 AM
Nipperdog's Avatar
Nipperdog
Bellmore Long Island
  #29
Old 07-22-2017, 08:00 AM
Overkill2's Avatar
Overkill2
Nice...downstate. Near the Big Apple...Probably about 8 hours away from me. Enjoy!
  #30
Old 07-25-2017, 05:14 PM
jfralph
jfralph is offline
Rushejj;
My trailers range from an empty 6x10' flatbed utility trailer to my fifth wheel with jeep in tow in the 15-16k rnge.
Quick Reply: Fuel Economy
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
