Cheap mods to gain horsepower
Old 07-20-2017, 05:31 PM
garrettsf250's Avatar
garrettsf250
garrettsf250 is offline
Originally Posted by fordman67
Yeaaa you probably need to read more and look at some peoples combos down below√
Stage 2s will need a non drop in type turbo and yet even more supporting mods. You said you didn't want to spend much but you are in the 6-8k mod range to do correctly plus a 4500 trans,suspension etc.
160cc injectors are more than the puny stock or drop in turbos really can cool get wise.
well if that's what it cost then I'm up for it...it's only money lol
Old 07-21-2017, 08:06 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Jarrett Campbell is offline
Old 07-21-2017, 08:22 AM
garrettsf250
Originally Posted by Jarrett Campbell
I know haha can't decide weather I wanna go big or not
Old 07-21-2017, 02:28 PM
Bill97's Avatar
Bill97
Bill97 is offline
You're confusing me. you said cheap mods. The things you're listing are many thousands of dollars. You must have one of those fancy jobs to where injectors, turbo, trans, HPOP, efuel, head studs, chip, gauges etc is being discussed as cheap
If you want to spend 10 grand to use stage II and up with reliability then go stage II with the supporting MODs. Personally my truck is for work, with the occasional on ramp WOT run. So I went the stage 1 route. I'd do those WOT runs A LOT more if I had a built trans. But since I don't, I baby it.
If you want to spend under 5K, I'd get Stage 1 sticks from Rosewood/Custom Tunes. EGT/Boost/Trans temp gauge. 6637 air filter. That will wake the stock truck up considerably. It's night and day. My favorite is when it's in OD on the highway cruising at 65, you can lean into the throttle just enough to spike the boost to 30PSI and it just sprints to 100 MPH or 1300 degrees on the EGT whichever comes first haha.
From there you can chip away fuel/HPOP/Turbo/Trans and other supporting MODs so if the itch comes to go bigger you will be ready. I'm having my water/meth kit installed today mainly to keep it cool while towing. However I'll be curious to see if I feel any butt dyno increase.
Old 07-21-2017, 08:39 PM
garrettsf250
that's exactly the response I was looking for. I don't have a fancy job I'm a heavy equipment mechanic and still learning. But yes I think stage one injectors and other small stuff will best suit me for now
Old 07-21-2017, 08:52 PM
fordman67's Avatar
fordman67
fordman67 is offline
But 50 psi on your small tow tune is SOOOO much more fun!!
Old 07-21-2017, 08:58 PM
garrettsf250
Sure if the truck could handle it but I doubt it
Old 07-22-2017, 09:22 AM
fordman67's Avatar
fordman67
Smh stock 342000mi mill and stock trans...lol
I like to live dangerously.
450/720 yanks my 28' camper right nicely.
Old 07-22-2017, 09:25 AM
fordman67's Avatar
fordman67
Why did we spend a page and a half then discussing crap for just stage ones and stock otherwise..smh
And married single income family wrench turner here..no Richy rich....just hard working driven determined here
Old 07-22-2017, 10:38 AM
garrettsf250
it wasn't a waste I was looking for different POVs all was appreciated I just think stage one would probably be best for me as far as money and performance goes
Old 07-23-2017, 11:59 AM
garrettsf250
My initial list of mods should have been my stopping point. I would suggest such.
3"/4" exh
6637 type or cai
Chip
Gauges
Efuel
T500
I had bellowed up pipes and no exh/oil leaks. I also had deleted the ebpv valve .
It went from 19psi then efuel&t500 cleaned up ALL exh haze and made 29 psi max. There are good gains to be had but even at that point it dynoed 200hp and 360tq.
Just make sure its running properly before leaning on it.
if got t500 would that put to much pressure oil pressure to the injectors?
Old 07-23-2017, 01:04 PM
fordman67's Avatar
fordman67
No,pressure regulated by the IPR. Its all about volume needed by the injectors under load. The larger pump when demanded via IPR can produce more volume where a stocker will increase duty cycle but run out of steam in some instances.
  #28
Old 07-23-2017, 01:09 PM
garrettsf250
Ahh I see I see. So the t500 is just a drop In hpop no need for cutting new lines or anything like that?
  #29
Old 07-23-2017, 01:16 PM
fordman67's Avatar
fordman67
Yea they modify the stock pump internals. Bolts in same as stock.
  #30
Old 07-23-2017, 01:26 PM
garrettsf250
The hard is probably getting the fuel bowl out of the way and all that right there then it should be cake after that yea?
Quick Reply: Cheap mods to gain horsepower
