Help fixing rear hatch defrost - Ford Truck Enthusiasts Forums
Old 07-18-2017, 09:36 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Weather is getting colder and I need defrost every morning.
Rear defrost doesn't work, and I found this when I opened up the rear body panels
Driver Side
Passenger Side
I cleaned both sides on the loose contact with sandpaper, cleaned with alcohol, and then superglued back together. Will the superglue allow enough electrical contact for it to work? Is there a better adhesive or way to fix?
I want it to fully cure/dry before I fire up. Hopefully in the morning my fix works.
Old 07-19-2017, 04:26 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Didn't work. Looks like superglue isn't conductive enough.
Will do research today to find conductive glue. Unless someone already has an answer
Old 07-20-2017, 12:37 AM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Clean it up really good and solder it?
Old 07-20-2017, 09:44 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
solder scares me. may crack the glass. I solder all my wiring, but IR Mekanic and it'd be just my luck to ruin that expensive hatch
gonna try this stuff. it has silver flakes in the putty to ensure electrical continuity. I figured my superglue fix probably wouldn't work, but I had to try
https://www.familyhandyman.com/autom...ogger/view-all
I'll update with results once I find a kit
Old 07-20-2017, 09:48 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Nice find on the kits!
Old 07-21-2017, 05:35 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Nice find on that kit with the flakes, looking forward to hear how it works.
But this that you posted on JULY 17th caught my attention.
Really? It's 0600hrs here in Philly and both of my ambient temp readings here at work say its 80*, I know that you are up well into New England but is it really getting that cold at night up there? We were up in Ontario in May/June and the nights were very pleasant then.
Old 07-21-2017, 07:43 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Low 60's and a few upper 50's recently
Couple with 80-100% humidity
The Dew and condensation doesn't burn off until 0800 roughly each day. And during my drive to work at 0430 each day the interior of all glass fogs over relentlessly.
Very wierd weather. I'm constantly fiddling with thermostat because the weather swing from night to day doesn't allow for a constant temp. House either gets damn cold, or too hot
Old 07-21-2017, 07:44 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Oh yeah, 90% humidity and 94F yesterday. But this morning was 63F and I had to squeegee the windows and let the Challenger idle a few minutes before it could cut the fog from interior
Old 07-21-2017, 08:00 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
OK, gotcha, I was thinking you had frost to deal with already!
Old 02-26-2018, 02:36 PM
red mistress
red mistress is offline
red mistress is starting off with a positive reputation.
Anyone successful on repairing broken connection for defrost ?
Old 02-26-2018, 03:20 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)
Old 02-28-2018, 04:21 PM
offroad_x's Avatar
offroad_x
offroad_x is offline
offroad_x is gaining momentum as a positive member of FTE.offroad_x is gaining momentum as a positive member of FTE.
Thanks for posting the fix. I have the same problem on my X. I'll give this a try!
01__Excursion
03-09-2019 02:49 PM
DDeffes
08-07-2018 11:59 AM
pkthomas
Vehicles for Sale
01-08-2018 07:42 PM
Thisguy65
32
06-24-2017 06:43 PM
Malibubobbi
05-04-2017 01:46 PM
Quick Reply: Help fixing rear hatch defrost
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
