Starting issues..
Old Jul 17, 2017 | 07:46 PM
jazz77's Avatar
jazz77
Starting issues..
I know that electrical gremlins are an issue with our vehicles but I'm really getting tired of the starting issue with my excursion. I have an '01 7.3 4wd with 365k on the odo.
My issue began with hard cold weather starts mostly due to a work out block heater. This eventually progressed to the starter burning out. Now it won't turn over, and doesn't even click. I was able to jump the starter relay and assumed it was the issue so I replaced it. Still no start by turning the key but was able to get it going by jumping the relay. Now even that don't work....any ideas before i take a shotgun to my truck(only partially kidding)?
Old Jul 17, 2017 | 07:47 PM
jazz77's Avatar
jazz77
Forgot to mention that I did change the starter of course....and also replaced the battery cables. I have an autoenginuity system if there is a way to use that
Old Jul 17, 2017 | 11:36 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Do you have a digital multi meter ?
First thing first, Voltage at each battery ?
Old Jul 18, 2017 | 10:59 AM
jazz77's Avatar
jazz77
I have one somewhere but right now all I can find is the cheap lightbulb tester ...i did hook the truck up to some jumper cables for awhile yesterday and didn't notice anything
Old Jul 18, 2017 | 01:53 PM
pirate4x4_camo
Dig out the Volt meter and get a baseline. Really no sense fooling with anything else until you know your batteries state of charge.
Old Jul 18, 2017 | 01:59 PM
agsmv1's Avatar
agsmv1
Be sure to check the voltages individually on the batteries. You can also watch the voltage drop by cycling the GP's individually on each battery. They should have a similar voltage drop when a load is added.
Old Jul 20, 2017 | 05:47 PM
jazz77's Avatar
jazz77
Well just a quick update: I can't find my multimeter but while using the cheap lightbulb tester I accidentally jumped the relay and was again able to start it. Apparently the short is somewhere before that. Is there any common places to look at?
Old Jul 20, 2017 | 06:05 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Check your neutral safety switch on the side of the transmission. It may be worn out or need to be adjusted. It allows 12 volts to go to the little wire (90 degree rubber boot) on your starter solenoid on the fender and activate it, thus sending 12 volts and lot of amps down to the starter. If you don't get that 12 volts "go" signal to the little wire, you won't get any juice to the starter. Wiggle the shift cable that is attached to the neutral safety switch and see if it starts by turning the key while wiggling. You will need a second person. Set the brake and chock the wheels, and make sure the person starting the truck won't benefit from you being dead.
Old Jul 20, 2017 | 06:14 PM
pirate4x4_camo
What relay did you jump ? Do you mean the starter solinoid ?
Have you checked to make sure the battery cable and trigger wires are tight down on the starter ?
Old Jul 20, 2017 | 06:18 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
If you had a short, you would know it...and fast. Smoke would be rising and fuses would be blowing. You have an open condition in the circuit. Quite possibly at the neutral safety switch or the ignition switch under the column.
Old Jul 20, 2017 | 07:04 PM
jazz77's Avatar
jazz77
Update part deux:
It's the relay or solenoid on the passenger fender that i was jumping to get the truck to start.
After reading up on the neutral safety, I tried to start it in neutral and it started right up. Has to be the safety switch right?
Old Jul 20, 2017 | 07:05 PM
jazz77's Avatar
jazz77
Forgot to mention, it did start in park once it had been started in neutral
Old Jul 20, 2017 | 07:56 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I would try adjusting the tension on it first. It's also called a "transmission range sensor", and the safety switch is built into it.
Old Jul 20, 2017 | 08:02 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Old Jul 20, 2017 | 08:23 PM
jazz77's Avatar
jazz77
Awesome! Thanks so much. I'll look over the videos and see what I can find out
OFD2413
Jul 11, 2015 08:53 AM
Singerjohn
Aug 19, 2014 06:27 PM
pkorrupted
1983 - 2012 Ranger & B-Series
May 1, 2013 10:09 PM
cajun1965
1997 - 2003 F150
Jun 29, 2012 05:26 PM
sternal2000
Oct 9, 2002 06:51 PM
