allison swap?
Old Jul 17, 2017 | 12:42 PM
SgtOtaku's Avatar
SgtOtaku
allison swap?
does anyone have info about swaping in a 6-sp Allison transmission onto a 6.9L F350 C/C? I'm planning to swap out the 3-sp C6 I have so I can actually achieve freeway speeds, and the allison looks like my best choice. I'm not worried about body mods to make it fit, but I am a little worried about running an electronic transmission on a mechanical engine, and mating it to an engine. I also haven't been able to figure out how to set up a gear selector for it, since I also want to move the selector off my column and onto the floor, like the Lokar cable-operated shifter.
Any help would be really appreciated and will help me get this part of the project past the planning stages.
Old Jul 17, 2017 | 04:59 PM
Franklin2's Avatar
Franklin2
Never heard of a Allison behind a old idi diesel. Most people get a updated and rebuilt E4OD and put it behind it, or do like I did and put a zf 5 speed behind it.
If you looked hard enough, you could probably come up with a idi to SAE bellhousing adapter and may be able to bolt up a heavy truck trans to it. I don't know, most people don't go that way.
Old Jul 17, 2017 | 05:04 PM
SgtOtaku's Avatar
SgtOtaku
What I'm trying to do is get the truck to be a bit more fuel efficient, be able to hit 80+ mph, and not have to use a manual. I got tired of running manuals as a trucker.
I can source a bus-grade Allison and possibly even the control panel from my work at a city bus agency. I might be able to have Allison re-gear and re-program it for light-headed duty, rather than bus. But all that seems expensive vs a 6sp Allison from a Chevy light truck.
Are there any other transmissions that are as reliable as Allison's, and will get me at least 5sp in auto?
Old Jul 17, 2017 | 05:24 PM
Franklin2's Avatar
Franklin2
The transmission selection for the old diesels is poor. If you want overdrive, the E4OD or the zf are the best and easiest options. You can also find add-on overdrive units, but if you put them behind a c6 you still have the torque convertor slippage, the c6 does not have a lock-up convertor. Does the Allision have a lock-up convertor? They are worth a drop of at least 200 rpm on top of the OD gear.
I will tell you your international diesel engine has a oddball international bellhousing pattern. Ford made a adapter to another oddball diesel only pattern(way to go Ford) that bolted to the back of the engine to use their oddball diesel pattern transmissions.
School buses and U-haul moving vans also used the international engine, as well as some dump trucks. These engine used an adapter to go from the oddball international pattern to a standard SAE pattern. If you want to play around with heavy truck and bus transmissions, you are going to have to find one of these SAE adapters.
Old Jul 17, 2017 | 05:42 PM
SgtOtaku's Avatar
SgtOtaku
Sounds like I'm gonna have a tough time with getting the truck up to where I want it.
so if I can source the bell housing adaptor, that will deal with mating the trans to the engine?
Old Jul 18, 2017 | 05:16 PM
Franklin2's Avatar
Franklin2
If you get the right SAE trans, it should bolt up. But you mentioned before about the trans fitting the truck and you are correct, those big truck transmissions are very large and heavy, and will probably hit the floorboard among other things.
You can start to get in the world of diminshing returns with these trucks sometimes. Some people put medium duty truck drivelines in these pickup based trucks, but they never think about the brakes, never think about the original GVWR of the truck itself, and don't think about DOT legalities when hauling very heavy loads. It can get out of hand quick.
Just remember, you are using a pickup based truck, even though it's a heavy duty model with a dually rearend. It is what it is sometimes.
Old Jul 18, 2017 | 09:29 PM
cadunkle's Avatar
cadunkle
What's wrong with a ZF5 or E4OD? Bolt up and you can cruise at 2000 RPM at 70 MPH with 3.55:1 gears. I doubt my IDI with 100cc pump and Banks turbo has the low end grunt for a double overdrive. Maybe empty and on level ground, maybe... But I'd wager it would lug and smoke and EGT would skyrocket. You'd need a turbo that builds appreciable boost at low RPM.
If you need more gears for heavy loads you can run a NP435 or T18/19 with a Ranger overdrive unit ahead of it. I'd sooner do a 2 or 3 speed aux trans before I'd go down the huge power robbing big truck trans route. These engines don't make much power to begin with, an automatic doesn't help matters and I bet those big automatics take a lot of power just to operate.
Old Jul 18, 2017 | 09:52 PM
Nothing Special's Avatar
Nothing Special
The E4OD is the only one of the 4 transmissions you mention that comes close for the OP. He said he doesn't want a manual.
Old Jul 22, 2017 | 02:34 PM
SgtOtaku's Avatar
SgtOtaku
So my area has freeway speeds up to 85mph. I am going to put on a stage 2 rnd idi performance turbo kit, which will give it more than enough grunt to run an Allison. And I want at least 5 gears so I can maximize fuel efficiency, and be able to run with modern traffic. The e4od is a decent transmission, with 4 gears. I may go with it if the Allison just won't work out. But at the end of the day, I hate running stick (did it too long as a trucker) and I want a rock solid, reliable trans.
Old Jul 22, 2017 | 04:05 PM
Franklin2's Avatar
Franklin2
I was thinking about your situation later on, and realized why putting that trans to that engine is so uncommon. Most people I read about put the tranny AND the medium duty engine in place also, getting rid of the old idi international. It's a good reliable engine, but it is limited in it's power potential. There are inline medium duty engines that have lots of potential power and can be turned way up that need a large trans like that. But like I said, putting all this in a pickup based truck makes it more of a play toy more than anything.
David85
29
Feb 14, 2026 08:30 AM
Papa Ford
Sep 7, 2011 12:07 PM
02X72
27
Jul 23, 2010 08:53 AM
tdp1968
Jul 28, 2004 05:56 PM
ceferino
Jun 6, 2001 05:06 AM
