Airbag Clockspring Video
Does anyone have a good video showing the airbag clockspring repair? I don't have cruise control, horn, and my airbag light flashes and stays on so from everything I'm hearing my clock spring is bad.
Also where can I find a used/discounted clockspring? The $150 pricetag isn't in the budget. Thanks for any help.
Those from Ford are usually discounted to around $200, retail parts houses usually sell Dorman for about $150 but if you can get the part number (they are different) Rock Auto will be the cheapest around $100 with a 5% discount you can google for.
Not a bad video, there are others. You just need to keep in mind the airbags can pop.
Mark, thanks for posting that. I've stopped looking at ANWB because for some time their shipping costs had been high. Since you put in the link I went and put one in my cart and shipping appears to be back to where it used to be. Tasca screws up some and it would be good to put ANWB back in the loop. I found Lakeland Ford also to have normal low discounts and low shipping.
A couple of links - just adding for "posterity". Keep us informed as to how the job goes. Sorry the parts are on the expensive side (but glad the shipping charges are reasonable again)!
https://www.ford-trucks.com/forums/9...ml#post8315477
https://www.ford-trucks.com/forums/6...l-removal.html
One way to find which part numbers are correct is go to ANWB and enter your VIN number before searching for parts. Also if they have your VIN number often they will check that you have ordered the right part. I ordered a 2007 part number trying to upgrade that part but they came back saying it wasn’t for a 2003, what they had in my profile.
turnkyle
09-07-2011 12:26 AM
ALP
07-25-2005 06:53 AM
John7894
02-24-2004 05:49 PM
deanfulmer
1983 - 2012 Ranger & B-Series
01-25-2004 05:25 PM
