Broke down and wont start.
#76
#77
#78
Any percentages down on the balance test?
It would be unusual to have any of the few pressure side o-rings in the lines not leak under pressure, but allow a Venturi style air leak during operation. But coming from a life of anything is possible, but not necessarily probable, that could be a direction. You would need to adapt fuel injection rubber line HFCM to fuel bowl. Doable, just not something I'd like to do.
6 cylinders were -40 and 2 were +40. It was explained to me that two injectors were bad and robbing the other six. Which is why you heard the knocking in the video. I hope I explained it right. The diesel tech that came over works on many types of vehicles(power utility) and has a cousin that is a diesel tech for ford. Which he called to verify his findings
#79
#80
Brian,
Actually I should have written the question better, compression balance percentages.
Injectors working/not working well would not matter with the knock as you were only engaging the starter during the bubble test (if you were jumping at the battery) so injectors were not being utilized. No electrical engagement of the injector and not pressurization of the fuel pathways so no way for the pintles to leak either.
#82
Brian,
#83
Compression numbers sound good.
I've only done the injector balance about a dozen times and only on my own truck with it running, so I have no experience on how an injector power balance should look on a non-running truck. But non-running, I'm having trouble conceiving how it's a valid test.
With that, I don't think I'm being any help in this thread so I'll bow out. Best of luck.
#84
#85
Still bowing out, but adding an aid for running then declaring (the mechanic) the injector balance test is telling anything is absolute BS, capital letters in bold. The test measures the rotational speed differences of each cylinder, which are altered based on combustion. If there's additional combustionable material being added by a different means then the injector, then your not testing the injector. The person needs his IDS revoked.
Yes, like Mom I was born without the tactful gene.
#86
Were you able to run a relative compression test? If anything is out-of-spec, how running a manual compression test? What do the results reveal? How about an injector buzz test? Do all eight injectors buzz/click when the test is run? Are any injector(s) circuit codes returned when running the test? And if so, do you have any known good injector(s) to plug into the offending cylinder(s) to recheck and rerun the test to see if it reveals the same result(s)? This is where I would be going at this point.
#87
So I don't want to throw parts at this in addition to everyone on this forum (which I do greatly appreciate all response's) I am having it towed to the dealer and see what they say. I just want it running. I can fix the coolant issue. I will post what they find. I did call BPD this morning gave him all the info I had and he is saying it is a fuel issue. But we will see. I would have taken it to BPD but they are booked out to the end of October.
#88
#89
So after two days the Ford dealer can’t figure out why the truck won’t start. They say they have ruled out all the normal problems. By all rights it should start and run. They said when they checked the injectors individually they all test good but testing them as a whole two were bad. I just want this truck running.
