2001 f350 7.3 cranks but wont start fuel pumps work ipr good all fuses good icp is next to be change - Ford Truck Enthusiasts Forums
Old 07-14-2017, 12:26 AM
Hinemanz Hinemanz is offline
Hinemanz is starting off with a positive reputation.
Okay i need some help i was driving my truck one day an it just died all it does is just crank over ive replaced the position sensor still nothing could the issue be caused by my ipr orings being broken?
Old 07-14-2017, 02:14 AM
DND58's Avatar
DND58 DND58 is offline
DND58 has a very good reputation on FTE.DND58 has a very good reputation on FTE.DND58 has a very good reputation on FTE.
When you first turn the key to start, do you see the "wait to start" light? Any smoke from tailpipe? Fuel above 1/4 and batteries good?
Old 07-14-2017, 02:16 AM
Yeah everything is good
Old 07-14-2017, 09:12 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
Disconnect the wires from the fuel bowl (leave them disconnected for now), replace fuse #30 under the hood, and try starting the engine. (Do it in the order I stated as well.)
Report back on the results.
Old 07-15-2017, 03:46 PM
mine only go up to 29
Old 07-15-2017, 05:38 PM
dn29626's Avatar
Is your truck running?
Mine is a 2001 as well. Production date 5/2001.
Old 07-15-2017, 05:40 PM
No i left my fuses out an ran to the store gonna try it when i get back
Old 07-15-2017, 06:52 PM
dn29626's Avatar
...Disconnect the wires from the fuel bowl..., replace fuse #30 under the hood...
I suspect the bowl heater is bad...and the above instruction is the cheap and easy way to test for that failure.
Old 07-15-2017, 07:00 PM
so i replaced the fuse an left it unplugged an tried starting it an still nothing do i plug it back in an try it
Old 07-15-2017, 07:17 PM
dn29626's Avatar
Since you mention only having 29 fuses in the engine compartment, make sure you are replacing the fuse for the fuel bowl water sensor & fuel heater.
Do you have a helper?
Old 07-15-2017, 07:38 PM
i replaced the fuse an tried starting it still nothing i tried unplugging my icp sensor an still didnt start
Old 07-15-2017, 09:37 PM
dn29626's Avatar
Have you checked the frame rail fuel pump?
For about 20 seconds after ignition key is turned to start position, the pump should make a humming sound and you should be able to touch it and feel it vibrating.
My quick suspicions are...
1)bad bowl heater causing a blown fuse
2)bad fuel pump
Check and get back with the result.
EDIT You can also run wires from the battery directly to the pump to test it.
Also, if you change the title of this thread many more members will help.
The title needs to indicate your problem. Help us help you.
All the title is doing is announcing that you have a 7.3 truck.
All of our trucks are 7.3 trucks.
Old 07-15-2017, 10:22 PM
2)bad fuel pump
okay i changed it yeah both fuel pumps work the ipr is changed all fuses an relays are good only other thing i can think of is the icp sensor cause i was going down the highway heard a puff of air sound an it just died
Old 07-16-2017, 02:09 PM
Sous's Avatar
Sous Sous is online now
Sous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud ofSous has much to be proud of
You can unplug the ICP sensor right at the connection on the head and the PCM will go to a default value. This is an easy way to eliminate that sensor being bad.
Old 07-16-2017, 02:48 PM
Quote:
still didnt start idk what else it could be
6.0 crank - no start Solvaysam 6.0L Power Stroke Diesel 11 07-31-2017 06:30 PM
Hpop ipr oil flow. michaeld563 6.0L Power Stroke Diesel 0 06-10-2017 06:58 PM
Hot crank no start jason poeppel 6.0L Power Stroke Diesel 71 05-21-2017 10:00 AM
Excursion 7.3 Idle speed increase and stumbling... bad IPR DavenTn Excursion - King of SUVs 3 05-20-2017 03:01 PM
IPR Problems hunter99992008 1987 - 1996 F150 & Larger F-Series Trucks 2 02-06-2016 12:09 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
