Towing issues with 2013 F250 6.2
on
K8,
Switch to MANUAL MODE on your transmission. Try it a few times to get used to it. You will fall in love with towing in manual mode. Changes the entire way the truck behaves as you tow.
Just try it. I pull 12K, the rig in my signature, totally bone stock truck with 3.73 gears.
And that's all I'm going to say this time, you guys have fun with your incoming "gears debate", I'm done getting involved in those.
tow haul... when going down hills... if you press on the brakes, the transmission downshifts 1 gear..
so if you press and release brakes several times going down a long hill.. it keeps downshifting till first gear.. so 30 mph could be in first...
but Computer will not allow engine to over rev...
but the going up hills it shifts down a bit earlier, then when going level..
Originally Posted by 82_F100_300Six
I haven't tried tow haul because somewhere I got the idea that it will downshift so hard you will look in your rearview mirror to see if your transmission is lying in the road. (I have no experience to say whether or not that is true.....)
Denny
What I like about manual mode and cruise is, the computer will wait until you have lost speed before it down shifts, a lot of times causing 2 downshifts. If your in manual, you can stay ahead of it and a lot of times, only 1 down shift is needed for the same grade. On the flip side, you can get back in your cruising gear quickly, where as with cruise the computer will hold that lower gear way to long in my opinion, especially if it goes even a slight down hill grade.
#28
#29
Have a 28' TT that I've been puling last couple wknds. Definitely sucks the fuel back at 39L/100kms
Ive been running it in T/H mode & I watch when approaching hills to drop a gear.
The guys running manual what RPM do you pick to switch gears at? Or is it all personal feel?
If you're talking up shifts, I really do that by ear as well but it seems like I'm in the 3500-4000 RPM range when or so when pulling the few times I have paid attention. I'll be pulling a skid loader tomorrow and I'll try to pay attention to when I shift. In Tow Haul it seems like the shift strategy really likes to let the engine rev. when getting up to speed which really seems unnecessary to me.
#30
