Need Advice on Removing Broken Bolt from Head (Upper Injector Hold Down Bolt Hole) ***FIXED!!***
So I'm finally installing cups (with Clay's cup tool) and following Riffraff's instructions (almost) to the letter...I set my torque wrench for 30 ft-lbs (5 ft-lbs shy of the recommended 35 ft-lbs). I started with cylinder #2 to practice then moved onto #4, #6, and #8. Things were actually going well and smoother than planned. Feeling confident I tackle #7 next while I still have patience. As the cup reaches the seat (I hope)...BANG! The bolt in the upper hole snaps before my torque wrench clicks. Wanting to finish since I opened the bottle of 620 I did the remaining 3 cylinders before lamenting on this new problem. On the last one (#1) same thing and the same hole (upper). Thank goodness Clay puts 4 bolts in his kit so I could get all the cups in but now I'm...in a pickle (family forum) with two broken bolts in the head and, of course, one of them is in the worst place (the dreaded #7 cylinder).
Upon visual inspection the cups look seated in #1 and #7 when compared to the other cylinders.
I'm going to try reverse drill bits to get them out. Has anyone conquered this mountain and lived to tell about it without removing the head? Any best practices/backyard tricks to share? I only have so many attempts before it's game over and I'm totally...pickled (again, family forum)!
FIXED!!!
I see by the views without replies that this is a conundrum for many.
As luck would have it the bolts were only finger tight and not bottomed out so I was able to back them out and remove them using a small screwdriver, pliers, and a straight pick tool. Took me about 30 tedious minutes to dig them both out. That does not include the 2 heartsick hours of frustration, pain, and agony that I went through before discovering the remedy.
The bolts were only finger tight and not bottomed out so I was able to back them out and remove them using a small screwdriver, pliers, and a straight pick tool. Took me about 30 minutes to dig them both out.
The bolts were M6 hex head bolts and are 2" long. Here's what is written around the head: H-K 129 USA M6 B480.
I wouldn't hesitate to use Clay's tool again...that thing is awesome! I don't know how unique these bolts are but, if I were to do it again, I would get my own bolts since I don't know how many cycles the one's in the kit have been through.
His current tool design is excellent on both fronts (removal and installation). Picture below.
The one on the left is the removal tool. Spin the top bolt until you get a good bite into the cup (most of mine were about 1/2-3/4 turn once it started to engage). Use a deep socket and ratchet (bottom nut) and remove the cup. When it's out I put the tip of the cup in a vice and used a 1" open end wrench on the threaded removal nut to get the tool off.
The one on the right is the installation tool. The bottom machined part fits the cup perfectly and the o-ring provides the perfect amount of pressure to hold the cup on the die. The bolt goes into a coupler/bearing so that when the cup makes contact with the head, the bolt rotates and inserts the cup but the cup and die do not rotate.
The one I have was obviously well used by its condition and the bolt issue I ran into. The units themselves are very solid and the threads in the removal tool were still fresh enough to grab the cups and remove them. I had a couple of times where the tool popped out as I was trying to engage the minimum amount of threads for removal so that it came out easier. I dropped a penny into each cup before removing it so there was no problem with debris/shavings.
There are some other nuances I developed through this whole process and I'll share those when I post a write-up of my 8 weeks (and counting) injector escapade. It won't be anything earth-shattering but I will share my experience and some of the little things that help me through it. Hopefully it helps someone. I'll get that started soon. I'd like to get the injectors in first since those holes have been empty for over a month.
buddy119
17
02-08-2019 09:31 AM
dulockdrumheller
04-13-2011 02:42 AM
palmercomputes
12-09-2006 06:07 PM
Pustman
08-11-2006 12:44 PM
KDH
01-20-2002 03:33 PM
