6.0 middle PCM connector
Did you do the things advised in your other thread (yesterday) on this issue?
https://www.ford-trucks.com/forums/1...lp-needed.html
Try unplugging sensors?
Get scan tool data?
Get scan tool data?
Get scan tool data?
Get scan tool data?
A lot of stuff. Here is the pin out description for the pcm connectors.
https://www.ford-trucks.com/forums/a...7&d=1340424187
A wiring diagram
https://www.ford-trucks.com/ford-man...%20diagram.pdf
I'm not sure how that info is going to help fix your issue but we all learn in different ways.
A wiring diagram
I'll have to look on my laptop Mark, I didn't realize this was the dual alt diagram when I posted the link, but I do remember having both. when I was on the Windows laptop I would save a copy of the actual document but on my iPad I just save links and hope the document doesn't go away on the web. That's the only link I have access to right now.
Just pulled the DTC codes. It's engine coolant temperature circuit high input, engine oil temperature sensor circuit high input, and injection control pressure censor circuit input low. I'm gonna try to unplug the ICP today and see what happens.
