Help! Can't get it to idle after rebuild. - Ford Truck Enthusiasts Forums
Old 07-12-2017, 04:16 PM
jstuller jstuller is offline
jstuller is starting off with a positive reputation.
Cool Help! Can't get it to idle after rebuild.
Welcome to my nightmare.
1987 Ford 2 wheel drive, 4.9L 3 spd. w/overdrive. Stepside. (handsome truck)
I hired a guy to rebuild the motor in my garage. He took everything apart and disappeared.
I hired another guy to complete the job. He did a wonderful job of picking up someone else's mess and put it back together handsomely. (I took the head and block to a machine shop to have them make sure the essentials were correct...)
The truck starts right up, but won't idle. He couldn't figure it out. I've had other people look at it and checked the internet. I've replaced the usual suspects, (map sensor, throttle body, idle control valve, replaced the gasket on the EGR valve, ignition control module. I believe I have sprayed everything looking for vacuum leak.
Suggestions?
Signed
Befuzzled
Old 07-12-2017, 04:37 PM
sandymane's Avatar
sandymane sandymane is online now
sandymane is gaining momentum as a positive member of FTE.
Quick question that may help with answers. Does the truck run down the road if you help the accelerator? Will it stay running with you giving it gas or is it just the idle you have the issue with? Sandy
Old 07-12-2017, 06:18 PM
Thank you for the question.
Just took it for a drive. At idle in 1st gear, it goes 18 mph. Give it gas, it takes off.
Shift to second, runs fine. Give it gas, it accelerates.
Hope that gives you clues
Old 07-12-2017, 06:22 PM
High idle
I should have stated: The problem is a really HIGH idle.
I don't have a tach, so I can't tell how high it is, but first gear takes me to 18 mph, and it feels like it's rearing to go.
Old 07-12-2017, 06:45 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Quote:
Originally Posted by jstuller View Post
I should have stated: The problem is a really HIGH idle. .
Thanks.. that is a very important detail because for most people a "won't idle" condition would be interpreted as a very low rpm and stalling condition.
A High idle condition is most likely a vacuum leak, either one of the intake gaskets is displaced or there has been an error or omission made with reassembly of the vacuum, EGR, or emissions components.
Old 07-12-2017, 06:47 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Sandy just went through this scenario....
High idle RPM indicates a vacuum leak.
He has a recent thread with tons of info and pointers on where to look.
and what Paul said above.
Old 07-12-2017, 07:00 PM
That's what I thought.
I had a BMW dealership mechanic over yesterday. He told me it was the throttle body spring not giving enough tension, so I replaced throttle body today.
I ran the EEC self-test codes just a minute ago and no codes showed up... not even a check engine light.
I will pull the intake and EGR & tube tomorrow.
Thanks
Old 07-12-2017, 07:09 PM
rla2005's Avatar
That's is probably your best bet.
Another quick test is to remove all of the vacuum lines from the vacuum tree (manifold). Run a dedicated line to the MAP sensor. Cap the remaining open port. Start the engine, if the idle is still high, you have a vacuum leak on the engine.
Old 07-12-2017, 09:03 PM
Scndsin's Avatar
Scndsin Scndsin is online now
Du Nawt Seek The Treasure
Scndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputationScndsin has a superb reputation
...I've replaced the usual suspects, (map sensor, throttle body, idle control valve, replaced the gasket on the EGR valve, ignition control module...
You're on your second replacement throttle body?
Are all the other replacement parts Motorcraft?
Did you save the old ones?
.... so I replaced throttle body today.
Did you get a 11 pass code?
Old 07-13-2017, 12:39 AM
I only replaced the throttle body once.
I went this morning to the junkyard and pulled three and chose one that was really tight out of a 95. (same part 87-96). It is a Motorcraft.
No codes at all. The check engine light never came on.
You guys gave great ideas.
I will try them tomorrow and let you know.
Old 07-13-2017, 12:58 AM
sandymane's Avatar
The post above yours is from an experienced member that can help you a lot as can others. Let him know if you got the 11 pass code so he can help you. Just trying to help another Texan. Sandy
Old 07-13-2017, 07:56 AM
Redark1 Redark1 is offline
Redark1 is starting off with a positive reputation.
you have to run codes to see if you get a all clear code. then you will know there are no codes present. do you have a code reader, if not get one if your going to keep the truck for a while.
have you tried to set the idle and how. there is a specific procedure. where is the timing set with the spout out.
Old 07-13-2017, 08:26 AM
Scndsin's Avatar
What ever you do, don't clean the TB blades. That can create the very problem you are trying to solve.
Do as Randy suggests. Dedicated vac line to MAP sensor (and I add one to the fuel regulator as well)
Replacing a bunch of parts with non motorcraft ones can often stack problems. I particularly don't trust aftermarket IACs, I'd rather clean a used stock one if you don't buy a new Motorcraft one
The aftermarket ICMs are all not made with Ford's blessing.
The only aftermarket MAP I bought failed in under a year.
Old 07-13-2017, 08:50 AM
rla2005's Avatar
Quote:
That procedure assumes there is no vacuum leak(s). For the most part if you do jack with the throttle stop screw, that's what it is...not an idle screw, it's to ensure the throttle blades do not fully close. This is done to prevent them from sticking in the bore.
Ford added some holes in the throttle blades at some point, which over time has proven to be a problem when the throttle bore/blades wear and allow too much air in when at closed throttle, which causes a high idle.
We could spend hours focusing on the throttle body, but there are many other problematic areas to investigate on these engine, especially the inline 6. They seem to be the most susceptible to this problem.
Some basic troubleshooting will eliminate an outside influence (rusted vacuum reservoir, broken vacuum lines, brake booster, etc.) or confirm it's on the engine.
EDIT: David was so kind to add adding a dedicated vacuum line to the fuel pressure regulator. Good call!
Old 07-13-2017, 09:40 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Oops, I can't take credit for that RLA. Scndin deserves that
But as was stated earlier, you need to plug the vacuum tee on the intake manifold. Only run a dedicated line for the FPR, the MAP.
​​​​​​That includes plugging off or blocking the PCV valve line. The PCV valve is a Metered vacuum leak.
You have to eliminate all outside lines going to numerous other controls to pinpoint a vacuum leak.
LETS SEE YOUR 67 TO 72 PICK UP HANDSOME 1967 - 1972 F-100 & Larger F-Series Trucks 994 Yesterday 04:10 PM
A Truck's Tow Rating is Whatever You Decide It Is; With 925 lb-ft of torque, every mode is tow mode MagicMtnDan 2017+ Super Duty 40 05-03-2017 04:06 PM
My projects mrpotatohead 1967 - 1972 F-100 & Larger F-Series Trucks 2 11-18-2016 11:43 AM
I'am still around guys i have not forgot the kingdom!! Jrob69f100 1967 - 1972 F-100 & Larger F-Series Trucks 7 07-14-2016 06:13 PM
Handsome and Hardworking Ford Trucks from the 1960s DerekShiekhi General Automotive Discussion 0 06-02-2016 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
