The Official Happy Hour Thread - Pull Up A Chair, Sit A Spell, What's The Latest? - Page 3 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Reload this Page >
  #31
Old 07-14-2017, 05:38 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Originally Posted by EXSwap View Post
The material seems to be cast aluminium and I'm not sure what corrosion, if any, would occur with the gas stored in there all the time.
Probably only react to any water in the fuel, long term.
Aluminum blocks, heads, and even fuel lines hold up to petroleum products pretty well, but if you're really concerned, KBS Coatings has stuff you can line the inside of a fuel tank with. I bet that would work for your pump, if it can be thinned enough to properly coat all of the smaller passages.
Stewart
  #32
Old 07-14-2017, 11:21 PM
High Cetane's Avatar
High Cetane
High Cetane is offline
High Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud ofHigh Cetane has much to be proud of
Too much to quote, but I'll jump in.
The fuel cell (deemed the MOAS) is indeed considered not serviceable, due to parts not being available. The decision for this approach was done in a room w/ many liability Lawyers, a coupla/3 Engineers, and someone from the USCG.
These folks (well, most of them) were terrified that someone working under the shade of a tree, might dive in to a high pressure (gasoline) fuel system, located in a bilge, and possibly cut a corner or miss something.
And so, an un-servicable item, with powder-coat mistakenly applied to a surface in contact with gas (worse, an ethanol-like solvent) created this debacle.
Sidenote-While the Torx screws used to assemble are not considered "Tamper-proof", the first time you disassembled it, you might recall you had to dig out epoxy for the torx-bit. This epoxy was the "tattletell" that someone tampered w/ the MOAS. I'll let you guess who insisted on this and why.
Do not worry about corrosion affecting the inside of the bowl. If H2O is getting past the filter(s), especially the one actually on the MOAS, you'd have bigger problems. Leave it bare and let your filter/separator prevent the corrosion's cause.
* Disclaimer* The following are suggestions on servicing a non-serviceable VP MOAS fuel cell from a tired, upper middle-aged guy w/ poor memory and far too many miles.
Use Lacquer Thinner/MEK, or similar, to remove paint/PC from inside of cell.
Replace all o-rings. You will have to go aftermarket. This includes the o-rings on the lines themselves. They really are sacrificial and not intended for re-use. Use motor oil on them and their ports on reassembly.
Fill a new filter prior to install & initial dry start. The "first" pump is a low pressure pump, its "lift" ability is next to nil. Neither the LP or HP pump tolerates any dry running.
Cycle the key several times to let the pumps run to get fuel psi up prior to starting..all while checking for leaks. (Unplug the high side, and just run the LP for 1st leak check)
Above all else, make sure you have no leaks after reassembly....all with new o-rings.
Did mention to use new, (correct material Nitrile) o-rings, and check for leaks?
MOAS...Mother Of All (fuel) Systems....Wadn't me, I was too busy dealing w/the green ones.
  #33
Old 07-15-2017, 06:01 AM
05MilMachine's Avatar
05MilMachine
05MilMachine is offline
05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future05MilMachine has a brilliant future
We call this "yardkill". It is the good parts of an old Kawasaki Mule 500. It has the fe290 industrial motor that was used in a lot of golf carts and other than needing re-ringed and belching oil smoke and, it runs pretty good. Also repels bugs. It might be the most fun $100 can legally buy you on Craigslist. It will be this Winters welding project.
  #34
Old 07-15-2017, 04:40 PM
Excurvelle's Avatar
Excurvelle
Excurvelle is offline
Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.Excurvelle has a spectacular reputation.
I bought a John Deere L100 this spring that had a blown engine, I put a 20 year old Craftsman engine in it, added an electric fuel pump and cut off switch. The rascal runs good. I am having belt issues. Now that most of the car emergencies are done for now I want to see if I can get this FrankenDeere cutting the grass.
  #35
Old 07-15-2017, 05:37 PM
mecdac's Avatar
mecdac
mecdac is offline
If it flies, it dies
mecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputationmecdac has a superb reputation
Found a game on the phone, very addicting. I've never played any online games but this is a trivia game. You pick your topic(s) and play against random opponents, friends or play against the bot with wild card questions.
My topics: US States, US Historical Figures, US Presidents, MLB Basics and a few others.
  #36
Old 07-17-2017, 11:21 AM
EXSwap's Avatar
EXSwap
EXSwap is offline
EXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to allEXSwap is a name known to all
Great info! Thanks! One item you mention I haven't dealt with is the o-rings. I need to pull it all apart and find aftermarket replacements, and stock an extra set or two. I'm always very careful to make sure I don't have any leakage and check it on every startup. Kinda like running the blower for a bit before hand. I haven't personally seen a boat go up in flames, but I've seen enough videos and "after" pictures. It ain't pretty. I do remember the epoxy on the screw heads the first time I took it out. Good news is, after the fuel pump cleanout and spending 5 hours pulling every ground I could find, cleaning it, and reinstalling, no more trouble codes or engine alarm. Running pretty good and was able to get out on the water for some much needed R&R this weeknd.
  #37
Old 07-21-2017, 03:50 PM
Stewart_H's Avatar
Stewart_H
Fantasy Baseball and Plants vs Zombies 2 already have my attention, behind FTE. I don't need another excuse to not be productive during the day!
Stewart
  #38
Old 07-30-2017, 07:37 PM
mecdac's Avatar
mecdac
mecdac is offline
Well there's a meteor shower and a Total Solar Eclipse
just like
sang about. An apricot scarf and all.
For Buddha's sake I've got to put new injectors in.
  #39
Old 07-31-2017, 05:01 PM
Twitchyleprechaun's Avatar
Twitchyleprechaun
Twitchyleprechaun is offline
Not So Nice Leprechaun
Twitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputationTwitchyleprechaun has a superb reputation
So my business partner signed us up for this thing..... August 11th. Link for info below....yes there will be pictures, don't worry.
https://www.firstgiving.com/fundrais...her-shoes-2017
  #40
Old 07-31-2017, 05:38 PM
gots_a_sol's Avatar
gots_a_sol
gots_a_sol is offline
gots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant futuregots_a_sol has a brilliant future
Lost my old man on the 9th
He has taken up residence in the garage so I can yell at him when I can't find and/or break something
Also started driving this truck part time.
  #41
Old 07-31-2017, 06:42 PM
mecdac's Avatar
mecdac
mecdac is offline
Sorry to hear that, Joe. At least he has a nice view.
  #42
Old 07-31-2017, 06:53 PM
Oldguyfl's Avatar
Oldguyfl
Oldguyfl is offline
Oldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant futureOldguyfl has a brilliant future
Anybody like cool AR stuff?
AR-15 3D Full Float Handguards
  #43
Old 07-31-2017, 10:20 PM
Nicmike's Avatar
Nicmike
Nicmike is online now
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Joe, I hope he was good and old when he went. If not, I am sorry to hear about him passing. Like Mark said, he has a good view! Nice of you to give him the high ground.
  #44
Old 07-31-2017, 10:21 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Only in .308 or larger...
  #45
Old 08-01-2017, 08:43 AM
WE3ZS's Avatar
WE3ZS
WE3ZS is offline
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Joe, Sorry about your Pop passing, but I think it's pretty awesome to have him hanging out in the garage with you now.
And driving that rollback will be very handy, I think you have posted more pictures of projects on trailers than anyone else here.
Quick Reply: The Official Happy Hour Thread - Pull Up A Chair, Sit A Spell, What's The Latest?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
