Just scored a 1960 Ford F500
Old 07-10-2017, 03:07 AM
eddietude's Avatar
eddietude
eddietude is offline
Just got an interesting vehicle 1960 Ford F500 with a bucket assembly on the back.
Runs and drives, needs some brake work, and I just started reading about the widowmaker wheel issues.
Few questions:
Anyone know of a dual res. master brake cylinder that will direct bolt into this thing? Not a fan of single res master cylinders.
Wheel replacement options?
Thanks!
Old 07-10-2017, 03:08 AM
eddietude's Avatar
eddietude
Also, do I need to worry about those wheels blowing apart when I take the rims off the vehicle to service the brakes? Thanks!
Old 07-10-2017, 08:50 AM
truckdog62563's Avatar
truckdog62563
truckdog62563 is online now
Marmon-Herrington Man
Please post more pictures showing the other side of the truck, and inner duals as best you can. The right front and right side outer dual are NOT widow makers. They are the locking side ring style that are safer to work with. Removing them, and others like them, should be safe. Letting the air out of any such tire before removal is a precaution worth taking. Then while reairing use a clip on chuck while standing off to one side. If you find other wheels on the truck have the widow maker RH-5° style outer rims replacement locking side ring wheels are available from several of us on the forum. Stu
Old 07-10-2017, 09:53 AM
eddietude's Avatar
eddietude
Thank you Truckdog.
That widowmaker thing has had me worried since I read about them. Both sides are the same, but I'll take pictures later and post them.
Were the widowmakers standard on these trucks, or were a few different options the norm?
Thanks again.
Old 07-10-2017, 11:33 AM
truckdog62563
Standard. Somebody (who is your friend) swapped them. Just make sure the inner duals were swapped too. Stu
Old 07-10-2017, 01:52 PM
eddietude's Avatar
eddietude
Thank you. Appreciate the info. Will get pics of the other side and inners later this week.
Does anyone know what years and trucks the widowmakers were generally used on?
Old 07-10-2017, 02:17 PM
truckdog62563
The first reference I have showing them is 1948. They were for many years the dominant rim design used by Ford, GM, and Studebaker (through cessation of production in 1963/64). It seems Dodge and IHC never used them. They survived a NHTSA/IIHS federal recall effort initiated in the early 1970s but did not survive intact. The sole material outcome of the failed recall was industry's agreement to cease their production and sale. Budd and Motor Wheel last listed them in 1972, Kelsey-Hayes in 1976. The legal, insurance, and service industries are driving them out of service. Those of us in the hobby are left to find alternative wheels. Stu
Old 09-16-2020, 06:02 PM
Nzkiwi's Avatar
Nzkiwi
Nzkiwi is offline
Few questions:
Thanks!
Hi there are you able to help me out with a few wier colours and where they go in behind the lower turret control box as im currently rebuilding one that had been pulled apart... Light green and black where do these attach to ? that are attached to the 14 pin plug that goes to up the basket
Hope you can Help
NZ Kiwi
Old 09-17-2020, 08:37 AM
JohnNewb's Avatar
JohnNewb
JohnNewb is offline
Hope you can Help
NZ Kiwi
bucket and controls would have been by aftermarket company (like my dump bed stuff). Good luck finding wire diagram.
Old 11-01-2020, 06:24 PM
TonySimpson's Avatar
TonySimpson
TonySimpson is offline
59 f500 rear brake issue
I am learning how to post a question on this site as a new member. I hope I am doing it correctly.
I just bought a 59 f500 and have it at an ag repair outfit for brake service. They say they have never seen a truck with this type of rear setup: with 2 wheel cylinders on each side. Is this the "heavy duty" brakes? They said they had received kits for them but they would not work.
I told them I was unconcerned about saving a few bucks and ask them to simply replace all wheel cylinders all around. They have had trouble finding them.
I tried LMC Truck and cannot locate them there.
I would appreciate any links to rebuild videos as well as I cannot find any specific to the 59 f500.
Any part #s or suppliers for those cylinders, gentlemen??? I'm eager to get this girl on the road!
Old 11-01-2020, 06:39 PM
matthewq4b's Avatar
matthewq4b
matthewq4b is offline
I could look them up but NumberDummy is way more experienced than I in tracking this stuff down (as are others) so maybe now that he has been linked to this he may chime in and provide you with a Ford pt# that can be cross-referenced.
Old 11-01-2020, 07:17 PM
JohnNewb's Avatar
JohnNewb
JohnNewb is offline
Can't help with brakes but better to start a new post rather than adding to another. Your question may get missed. LMC only lists f100 and 250.
Old 11-01-2020, 07:25 PM
hobohilton's Avatar
hobohilton
hobohilton is offline
Those clinch ring wheels have been around a long time and have served well. If a ring is going to blow off, it usually happens when a tire has been removed / repaired / replaced. that is why the heavy duty tire shops have a "cage" to mount the wheel in when it is inflated. What kind of service are you going to put the truck into?
Hobo
VitaminC
19
07-15-2017 04:42 PM
31hillard
1947 and Older Ford Trucks
07-19-2014 10:54 PM
mprsox
09-17-2009 09:41 AM
O2SLED
11-13-2008 04:56 PM
oilcan
01-22-2006 01:04 AM
Quick Reply: Just scored a 1960 Ford F500
