77 f-150 choke not working
351m the choke isn't setting in the carb,It did well and good and just started this latetly, And the valves aren't great- but it smooths out really well when hot.If you can stand the time it takes warm this "cold blooded" ford up,Anyone have tips i might use ? Noone around my neck of the woods- is available for help.All the vacume hoses are good although original. I it mean will not kick the choke throttle plate closed , it used to snap it right shut, when this 351 was cold and running good.Truck .. My dad gave to me in his will. He bought it new- little history there . Its always been housed . bob s
thank you for reading this note
I presume you're referring to an automatic (electric) choke?
The factory choke is different from aftermarket choke, but neither need vacuum.
The factory choke is AC and is powered by the stud on the alternator.
Aftermarket chokes are DC and are powered by a switched hot.
The AC hot from the alternator is hard to measure with a cheap meter because it's actually AC. On DC chokes, sometimes the wire comes off or a fuse blows
Either way, the choke should be "set" by pressing the gas pedal all the way to the floor. The linkage will then engage a cam. The cam is adjusted by turning the black round choke housing. Full closed should be about 1/8" upen.
You can give the choke power (make sure it's the correct type-AC or DC) and watch it open. It should open fully vertical after about a minute
The following users liked this post:
ps; I did turn the black housing towards richer ......It was turned back again by me , but still on the lean side. bob s
Picture of 3 ford trucks above. The goldish brown looks just like mine- BUT MINES A f-150 PAPABEARYUMA S TRUCKS
PAPABEARYuma So theres a fused line...from the battery to the carburetor there somewhere,is that a fueable link type? thanks bob s
Hi Bob,
You should have a steel tube going from the choke housing down to a plate in the intake manifold ( if you remove the plate you will see a coil of metal tubing, DON'T remove the plate unless you have a new gasket for it; I have a Felpro gasket # here somewhere).
The choke works by drawing heat from the coil in manifold to the choke housing, SO 1st - remove the tube from the choke housing and check for vacuum at the choke housing connection, if no vacuum the port in the choke housing may be plugged; 2nd - try blowing air thru the manifold coil; 3rd - If no air flow, try snaking a small stiff wire (speedo cable core) thru the manifold coil.
You say that you have lubricated the choke linkage etc., - with the engine off and cold, hold the throttle partly open and the choke should close fully, if not - remove the choke housing and check the condition of the thermostatic choke spring. Dunk it in a pot of hot water and you should see the spring tab move.
Then manually move the choke plate; several things should happen - the choke plate should move freely to the full closed position and the stepped fast idle lever should move freely without binding.
When you install the choke thermostatic spring back on the carb make sure that the spring tab is on the correct side of the lever that moved the choke plate. To adjust, you will see a long line and shorter lines on the thermostatic choke housing, start with setting at the long center line. You can adjust the tension by rotation the housing after you make sure all else is working properly.
Nat
Nat
The truck in the middle is a 78 F150 with a 351m. It formerly had the factory 2 barrel carb on cast iron manifold. The carb had the heat stove element that went into the intake manifold and factory AC choke. If I remember correctly, the wire for the electric choke came up in the harness with the oil pressure and coolant temp senders. The electrical diagram says that the white/black AC comes from the orange on the alternator.
I've since replaced the intake and carb, and the new Holley electric choke runs off the battery isolator
