Good source for hardware and fasteners
So i'm slowly reinstalling all the trim that has been removed from my 90 F150. Most of it hasn't been an issue to find hardware for different trim (clips, plastic rivets, etc), but one of the things i'm having trouble is fasteners for the metal trim on the tailgate
By that i mean the cover that goes over top of the FORD script in the tailgate itself; basically i'm missing two of the little studs that help bolt it to the tailgate, as well as the screws that go through the tailgate to hold this panel on from inside
Hopefully it makes sense what i'm describing
In any case, anybody have a good source other than junkyards for these pieces? or am i better off trying to find another one thats not broken
Thanks in advance for any answers, smart **** or otherwise
The best source for HARDWARE and ATTACHING PARTS is FORD. But, it can be expensive. Some parts are only available from FORD (some molding clips for example).
The MPC PARTS ILL will give you the STANDARD HARDWARE PN. If obsolete, you can usually cross over the PN to DORMAN, AUVECO or LAWSON PN's.
Ford Clips And Fasteners
Might not have what you are looking for, but a good source for Ford hardware none the less.
Thanks for the lead eakermeld
grapegringo
08-19-2016 01:53 PM
Jimmyrig
08-20-2013 02:12 PM
