Relay module
Old Jul 7, 2017 | 11:57 PM
Mikeman's Avatar
Mikeman
Relay module
I picked up a '99 Mountaineer with some electrical gremlins for $350. I looked in the EVTM and it shows a relay module under the dash on the driver's side. It has three rows with two relays in each row and one larger relay at the bottom. None of the documentation I have tells me which relay is which. It got me to wondering if there should be a cover that has this information. Is there supposed to be a cover? If so, does the cover tell you which relay is which?
Old Jul 11, 2017 | 02:44 PM
87 XLT's Avatar
87 XLT
I guess there are times when even the EVTM is useless. I poked around on the internet, thinking there must be somewhere that shows these relays, but all i could find was the under dash and under hood relays/fuses.????
I would check with a Ford dealer parts department, they might be able to pull up an exploded view of the relays.
Congrats on the new Ford. .
Old Jul 17, 2017 | 07:31 PM
Mikeman's Avatar
Mikeman
Well, I went to the junkyard and found a relay module cover. Nothing on the cover that indicates which is which. My need for knowing has gone away at the moment as fixing the power window door ground has made the strange behavior go away.
I bought the relay cover so that the Mountaineer is more complete now. I might just go to the library and see if the Haynes or Chilton's manuals provide any clues before I run out and buy one. I've noticed that sometimes the non-Ford manuals do provide some useful tips / shortcuts for certain things and I don't mind paying for textbooks as part of my education if the books provide value.
Old Jul 18, 2017 | 03:47 PM
87 XLT's Avatar
87 XLT
Congrats on finding the window problem.
I'm going to the Kia dealer today and Ford is right next door. I'll see if they can tell me anything on this.
Old Jul 18, 2017 | 08:05 PM
87 XLT's Avatar
87 XLT
No joy at the dealer, they say to check the owners manual which i presume didn't come with the truck
Like you say maybe Haynes or Chiltons will have the info.
Old Jul 18, 2017 | 10:30 PM
Mikeman's Avatar
Mikeman
Thanks for checking with the dealer.
The owner's manual is online and doesn't cover the relays in the relay module - only the relays in the box under the hood. One of the relays is bigger so I guess I could pull it and search the part number and see what comes up. But that only gets me one of seven. There are still 6 identical relays to figure out.
Old Jul 20, 2017 | 06:39 AM
shorod's Avatar
shorod
Is there any chance you can post a picture of the relay box you are referring to? Maybe it's actually the Generic Electronic Module (GEM) or something else that someone will recognize by the photo.
-Rod
sdregi
1978 - 1996 Big Bronco
May 16, 2012 02:01 AM
jporterOCCC
May 6, 2011 08:35 PM
fordman311
1997 - 2003 F150
17
Oct 18, 2005 08:40 AM
pitrow
Sep 17, 2005 10:40 AM
BIGEARL
Dec 18, 2003 05:02 PM
