F25 question and vin help
Here's the full decode. Like I say, if this doesn't sound right for one of your trucks then the door was probably swapped and the tag wasn't.
F25 = F250-2x4
Y = 352 2V
P = Twin Cities, Minnesota Assembly Plant.
844558 = 1966, assembled April 1966
129" Wheelbase.
B = Caribbean Turquoise
F250 = F250 2WD, 7,500 lbs. GVWR
381: 3 = Medium green crush vinyl and medium green wicker pattern vinyl / 81 = 81A Standard Cab
A = NP435 4-speed
24 = Spicer/Dana 60 Rear Axle / 4.10-1 / Non-Limited Slip / 5,200 lbs. Rear Axle Capacity.
7,500 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
42 - Fargo, ND - Ford District Sales Office - where the original selling dealer ordered the truck from
Chad
F25 = F250-2x4
Y = 352 2V
129" Wheelbase.
A = NP435 4-speed
Chad
Hopefully this comes through OK. I've done the full list before in a table format perfect for a forum and it looked great for a few weeks and then it got scrambled. Here's a portion of that list. From the Standard Catalog of Light-Duty Ford Trucks - 1905-2002. First column is 1963, second column is 1964.
F100 4x4 Chassis & Cab 179 330
4x4 Flareside Pickup 967 802
4x4 Styleside Pickup 2,809 2,922
F250 4x4 Chassis & Cab 348 410
4x4 Flareside Pickup 865 1,028
4x4 Styleside Pickup 1,835 2,232
Enjoy!
Chad
Enjoy!
Chad
Yes, axles are 8-lug instead of 5-lug. Wheels were mostly heavier duty. Typically heavier duty choices like the Dana 60 in the rear. Springs were often beefier and/or more leaves and the frames were a greater "modulus" number, which took into account things like metal thickness, girth, depth of channel bends, etc.
And badging. That was about it in 63 and 64.
Chad
Chad
ALL 1956/72 F250's have a Dana 60 rear axle. Some 1973/84 F250's have a Dana 60 rear axle, some have a Dana 61.1 rear axle.
F100's have 5 lug wheels on a 5.50" bolt circle. F250's have 8 lug wheels on a 6.50" bolt circle.
thanks! even more clarification. The 63 is titled/registered as a F25, but is 4x4 (maybe a conversion). But it has 5 lug wheels, so maybe an axle swap as well? Or maybe a wrong title. Either/any way, i'll get em driving and protected from rust. Fun projects, and I didn't overpay for them. Glad I negotiated well. Gonna be drivers, not trailer queens.
For '65 and '66, both the F100 and F250 2WD 129" frames had the same modulus; 3.71. The 4WD 129" frames had a slightly higher 4.14 modulus.
The 65/66 short bed 115" 2WD frames had a 2.98 modulus and the '66 4WD short bed frames had a 3.17 modulus. There is no listing for a '65 4WD short bed, so I can only assume one wasn't offered.
The only difference in the 65/66 F100 and F250 frames are the 5097/5098 support brackets riveted to the frame that support the #3 cross member (back cab support). The F100 support brace only supports one side while the U shaped f250 part supports both sides of the cross member.
In '67 they lowered the modulus for the F100 2WD 131" WB to 3.06 while increasing the F250 2WD 131" modulus to 3.89
Those are the service replacements that are called out in the MPC - Notice the 1965 is calling out a part number of C6TZ-
They could cover both bases by having one service replacement frame so they didn't have to stock both parts.
I have the 1966 Salesmans facts book and it goes into vastly more detail and all F100 2wheel drive series came with 2.98 frame modulus originally.
Chad
Chad
harback
10-04-2017 09:45 PM
pauldahle
03-09-2007 05:42 PM
