A/C issue - high pressure on low side & low pressure on high side
I was helping a friend with his A/C. It's on a 2008 Mercury Mariner (Ford Escape). It's a hybrid, and has a belt-driven compressor. It has not been cooling as well as it should since last summer, but it does cool a little (air at vent today was 60-70 degrees when it was 95 outside).
Compressor comes on and stays on - there isn't any cycling off and on.
With ambient ~95F and idling at ~1000RPM, low side = 70-75PSI, high side = ~170
Increased engine RPM to 2700 (highest it would go while in driveway, I assume due to some hybrid feature), and low side went to 55PSI, high side to 210PSI. Let off the gas pedal and it went back to 75/170PSI.
According to all charts, at 95F it should be 50-55PSI on low side and 275-300 on the high side. I haven't found much info for when the low side is too high and the high side is too low, other than possibly something restricting flow or a weak compressor.
Thanks for your help,
-Chris
-Chris
WhoIsJohnDoe
05-03-2018 12:50 PM
