dual exhaust system Ford F100 1956
I'm not exactly sure. There aren't as many V8 firing orders as it might seem at first glance, because different manufacturers designate a different cylinder as the #1, or start the sequence differently, if this is allowed for then the number drops to just a few. I think they all basically fire the outer 4 cylinders and then the inner 4 though.
@Abe: different firing order means different sound! Even today with the modern Coyote engines you can hear the difference. Once I had a direct comparison with a 289 and a 351 in a '67 Mustang. The point is, that by different firing order, the sounds, implied through the single exhaust valves can overlap or not. That makes the difference. Overlapping soundwaves so to say
F-1
07-03-2016 08:01 PM
Darknight88
01-26-2011 10:29 PM
