What year 460s interchange with a 93?
I have a 93 F350 crew cab 4x4 long bed that is in need of a new engine. What years are interchangeable? When i look up long blocks they say 92+
i found a deal on a compete running 87 trick with a 460 I'ike to swapin if possible...
my poor nissan titan just isnt a wood hauling machine like this truck.
What you want is a crate engine from this guy. He will help you build it yourself if you would rather do it that way.
1994 Ford 460 mild performance upgrades - 460 Ford Forum
Heads changed when they went from carb to EFI. Carb heads have round ports, EFI heads have rectangular ports. If you stick with the EFI intake, you're gonna need to use your old heads as well. Same deal with exhaust manifolds. Short blocks can interchange, but you probably want a newer top end if you're trying to keep it simple.
https://www.ford-trucks.com/forums/1...0ve-heads.html
http://www.460ford.com/forum/37-engi...0ve-heads.html
http://www.460ford.com/forum/37-engi...e7te-f3te.html
Beyond that there are aftermarket intakes built to make injector installation simple.
I might rebuild mine down the road, its got a ton of crankcase pressure so it blows oil out of the breather hose like crazy. Think it started as a intake gasket allowing the EGR system to pump into the engine but its been overheated several timessince then so i worry i blew a headgasket(s) or warped the heads...honestly haven't torn into much but it was driven hard for a long time
I never really dug into the 460 efi swap question too much. Off the top of my head I can't think of any huge external differences. You might get lucky and find a rare MAF version and have to switch some parts.
Internally I think the pistons and heads changed. The later version is probably a little less detonation prone, (better quench?).
There is a "school bus version" you would be better to avoid. (Maybe 7.0L) Dump trucks, etc.
Pickup, van and motorhome engines should swap without making you want to kill yourself.
For any swap you are way ahead if you have a running donor parked right next to your truck.
Post lots of pictures if you do this.
http://vehicleidentificationnumber.c...ord-truck.html
8th Position – ENGINE TYPE
G 8-460 (7.5) EFI
L 8-460 (7.5) 4BC
Diesel_Brad
10-09-2010 02:42 AM
atomicjoe23
08-18-2010 09:37 PM
jab55
04-20-2008 02:18 AM
82F100SWB
06-02-2004 09:18 PM
