Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
new item to add to the ford 6.4l PSD issue problem list
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 07-06-2017, 06:13 AM
speakerfritz's Avatar
speakerfritz
speakerfritz is online now
speakerfritz has a good reputation on FTE.speakerfritz has a good reputation on FTE.
so I ran into an new problem which I never heard of before on a ford....harley yes..ford no. there is a drain pipe that connects between the turbo and the engine. purpose of which is to provide a way for the oil that feeds the turbo bearings to return to the crank case. the design is simply a tube with an oring on the turbo side which just slide in with no lock down and on the engine side theres 2 bolts. so the problem is the oring will eventually wear and allow opil to drip down the exhaust manifold trailing edge, and then drip onto the ground, garage floor, etc. Im not too concerned with the oil drips which looks like about a quarter of a teaspoon...but the problem is the oil dripping onto the exhuast manifold is generating quite a bit of smoke and at stops or idles...the fumes are getting into the cab. cant be good for your lungs.
so the fix is to remove the turbo (good luck with that) and replace the seal which is part of the turbo install kit.
looking at the nuts and bolts involved I doubt this can be down with out breaking a rusty nut , stud, or bolt.
I just got done lifting the cab to do a rocker job and not looking forward to this one.
if the flange would have been on the turbo, instead of using the tube as a flange...it would not leak.
Old 07-06-2017, 04:45 PM
jimh425's Avatar
jimh425
jimh425 is offline
jimh425 is starting off with a positive reputation.
I think your engine had a hard life to be so low on the miles. Mine at 120K doesn't have this issue either.
ak-angler
Modular V10 (6.8l)
301
10-26-2018 08:34 AM
Wyatt66f100
09-10-2018 01:04 PM
Fat Diesel
190
02-12-2018 02:28 PM
Firefighter 1406
19
08-25-2017 08:11 PM
SgtRauksauff
04-12-2016 09:50 AM
Quick Reply: new item to add to the ford 6.4l PSD issue problem list
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
