94 F-150 with just a few issues.
S=1995
T=1996
So if it is a 1995 MY truck it will be OBD-I. If it is a 1996 MY it will be OBD-II.
What exactly makes 96 intake & TB cover unique?
Only way I know to ID under the hood a I vs a II is the diagnostic port ain't there in the corner, no air pump & count the number of wires on the mass-air meter.
Did any 95 4.9's come with a MAF or OBD2?
Your truck is exempt from OBD-II since the GVWR is above 8500 lbs. That's why it's still Speed Density OBD-I.
Alright, got the codes.
KOEO
122 for the throttle position sensor below minimum voltage
542 fuel pump secondary circuit fault
Constant
122 again
128 MAP sensor/vacuum hose disconnect or damage
332 insufficient EGR flow detected
542 again
Didn't do KOER because they can supposedly be skewed while the system doesn't pass the KOEO.
Any suggestions on where I should start?
KOEO
Constant
122 again
542 again
For the fuel level not reading. I think the gauge shkuld sweep. But if you have to replace the pump it is dropping the tank.
The fuel mileage can be related to many things. As far as o2 sensor, fuel pressure regulator, needing a tune up, and the list can go on. Get the codes and write em up when you get the new tools! I have the same tool and it makes things alot easier
Quick444
08-27-2018 07:34 AM
jpcnorthwood
92
01-04-2012 06:18 PM
