Mike's F100 Build
#31
#35
#37
#38
Let us know. I hadn't heard of the fuel pump being different, and the catalog says they shouldn't be. But, there are errors in the catalog, for sure. And when I find them I make notes in my copy, which then usually shows up on my web site.
But, do you know that the engine is original to the truck?
#39
I don't have full history on the truck. Everything appears as it would with an old truck with light mileage. I don't see much out of place. I can tell left front fender was replaced. Left inner fender is cracked in several places as you would expect with a minor fender bender. I will get to cleaning all the grime off the engine and recording the engineering and casting numbers. First I want a reliable driver. Even then I will not know that this is the original engine. Any advice on how to tell if this is the original engine is very welcome.
#40
On the fuel pump, it appears the mounting surface on the pump could be either pattern, as the block is surfaced to support either. I think the pump I got at the auto parts store had been put in the wrong box. The plastic sealed bag was not sealed. The number on the pump did not match the number on the box, in the box were three gaskets. The height and length were very much shorter than the one I took out. There are new ones due in on Monday and I will know more after inspecting them. I am suspicious that it is possible a 1/80 truck will have a 12/79 engine.
I also do not understand the air pump setup. It appears to dump air into a single large port directly under the carb. Do you know if this is correct?
#41
I don't know about air pumps on those. I'll look at the catalog, but there's another thread on here about air pumps and things changed several times over the Bullnose years for that engine.
On the fuel pump, I'll bet you are right about the pump you got. Too many people return things in the wrong boxes. I usually refuse to take a part in a box that's been opened. Tomorrow will tell.
#42
The closest match fuel pump was from the 1979 4.9L I6. The 1980 pump was about 1/2 inch shorter than the pump I removed from the tuck. I used the 1979 pump.
I also did a full oil change with another new filter.
This was a precaution just in case fuel leaked from the fuel pump into the oil.
