POWER BRAKE ON FIREWALL WHO'S DONE IT?
on
I used factory stuff too...
http://www.fordtruckzone.com/threads...-f-100.655090/
and this might help
http://jniolon.classicpickup.com/plu...iscbrakes.html
later
john
and this might help
later
john
I bought the Performance On Line setup. At $289.99 it is $200.00 less that the same units from others. And the others look exactly like the POL unit without the decal. I haven't installed it yet. It and the MII front end are sitting in the bed awaiting my mechanic to install them.
https://www.performanceonline.com/19...e-Booster-Kit/
Later!
Mr. Ed
Later!
Mr. Ed
Later!
Mr. Ed
Later!
Mr. Ed
I modified a 78 Chevy pickup pedal set, added the pendulum clutch pedal and pushed it all thru a classic industries double diaphragm 7" booster and reservoir. Can't remember who's clutch master I used.. drawing a blank there. Had to go slim on the booster due to the 496 shoe horned in there.
on
Curious on your paint EMAY do you have three different colors or is there that much flop in the paint ? On my truck I am also using a firewall mount my front and rear suspension are both 92 corvette so I am using the corresponding booster and master I had to modify the fire wall to get the proper angle on the resevor and with a little modding am using the corvette pedal assembly . Not a huge amout of work
On my 49 I built my own. I used a mid 90's Ford booster, an early 80's GM big car master cylinder. I fabbed my own hanging pedal assy utilizing some pieces (the pivot and spring) from a mid 90's Ford. For strength I tied the hanging brake pedal assy to the dashboard and the steering column
Good luck
Bobby
Good luck
Bobby
Received 4,120 Likes
on
