'16 vs '17 F250
'16 vs '17 F250
I have been planning for months to order a 2017 F250 CCSB Lariat 4x4. Been planning to order in July (next few weeks).
I have the opportunity to buy now a very low mileage 2016 F250 CCSB Lariat 4x4. I estimate that I will come out $2-5K less. Not a huge savings.
I'm asking for comments here hoping the biased 2017 guys don't slam this. I know what most of them think.
I want to see if anyone has any comments that I have not considered.
-- I know the difference in the transmission. 2016 is equal to what remains in the current 2017 F350.
-- I know a slightly heavier 2016 with metal vs aluminum in 2017.
-- 2017 does have new Sync3, ultimate camera a few options not found in 2016.
But....... are there any differentiating factors you know that I have not thought about??
Thanks for any comments/opinions ..... even alternative facts!!!!
I know little about ether one. but I have a 2012.
does the used one have complete records..? and what was it used for.?
for less then $5K.. I would get the New one.
but I keep things a very long time.. so use matters to me.
last truck for 11 years... and car before that 19 years. both daily drivers.
Thanks for the comments!!
I've had my current F150 since October 2007. It's an '06 and had about 22k Miles at purchase... now 186k. What ever I purchase I plan to drive at least 10 years.
on the 2016.... Records?? It has 8900 Miles. So it's had maybe 1 or 2 oil changes, that's it. Not to worried about records here. It is on a Ford dealer lot.
I passed on buying a 2016 in the fall to wait on some late year incentives / discounts on a 2017.
At this point ..... Before I order..... I just want to consider if there's any good reason to stay with a heavy metal '16 instead of going with the '17. By all accounts, from my reading, 2017 is a better riding / driving option wih a transmission better designed for the 6.2L .... which now has slightly better HP and torque specs.
From my reading the biggest issue with '17 is the body. Easier to ding and some are reporting paint issues (easily scratches, chips, etc). This does not appear to be a wide spread issue at this point but that could change. The Al F150 has been out a couple of years now and I have not heard the same on the F150.
Thanks again!!
Thanks again!!
I assume you are looking at a 6.2 gas because of your transmission comment. The 6.2 got a significant(I believe 30ft lbs) jump in torque, and at a lower RPM. At this point, I wouldn't say the new transmission is better, or worse. The 6r140 is extremely well proven in the '16.
I'm not a tech guy, I love my XL, so that stuff doesn't matter to me. The motor changes would pull me to the '17, but standing in front of the two, it would be a hard choice if they can get the price right, because I much prefer the looks of the 11-16 over the '17.
Thanks again!!
Thanks again!!
I would go and try out the 16 with the options it has and give it a good run and see how you like it, then I would test drive a 17 with option as close as your thinking you would like if you ordered one and take it and give it a good run and see how you like it.
Then I would go home have a cold one and write down the pros and cons of each truck including the price you could buy each at and then look it over after you have the pros and cons and think about what you believe is the best for YOU and what your looking to have either truck do for you whether it is towing , highway driving, work etc and go from there
This is the one thing that I don't really think I can ever get over. I would easily have accepted a non-flat rear floor in the crew cab in exchange for not having a truck look like its got a lift kit installed when its bone stock. Lifted trucks look goofy with small tires, and you can see this in the low-trim level 17s equipped with the smallest 275-65-18 tire option.
To the '17s credit, they have great positives in the chassis improvements and ride quality. But I'm just not a fan of the way the F150 cab was integrated into the Super Duty package.
I like the part about a cold one. I think that's the best advice.
Every day there will be plenty for sale and plenty that want to sell them to you. No need to get in a rush!!
