Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.4L Power Stroke Diesel
Reload this Page >
2010 F-350 6.4L DRW King Ranch making whistling noise during acceleration
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 06-29-2017, 11:09 AM
AVE8R's Avatar
AVE8R
AVE8R is offline
AVE8R is starting off with a positive reputation.
Hi Folks:
I have a 2010 F-350 6.4L DRW King Ranch. CAT & DPF Delete, Spartan Tuner, 66,000 miles.
It recently began making a whistle sound when accelerating, and I am noticing a small amount of black smoke coming out of the exhaust during the acceleration. Itís a whistle sound as opposed to a squeal sound that you might expect from a slipping belt.
The whistling sound occurs when the manifold/turbo gauge goes over roughly half or center position. When I let off the throttle, the noise stops.
I recently drove roughly 2,000 miles with a lot of rain, towing a 15,000 lb travel trailer. When towing, I use the Spartan 210 Tow Tune, and for every day use, Iíve been using the 300 tune.
The air filter was just replaced roughly 3,000 miles ago, but I am wondering if all the driving through rain and road grime could have clogged it to the point that the engine is sucking so hard, it developed a leak in a hose. If it isnít getting adequate fresh air, would that explain the smoke in the exhaust during acceleration. Obviously, I am most concerned if it is an issue with the turboís.
I bought the current air filter on Amazon and have ordered a new one. It is advertised as Motorcraft FA1886 Air Filter.
Amazon Amazon
Any input would be appreciated.
Thanks
Dave
Old 06-29-2017, 07:15 PM
Picton's Avatar
Picton
Picton is offline
Picton is starting off with a positive reputation.
Sounds like it could be a leak at the turbo seals. Another way to double check that would be to crawl under the truck and see if there is oil running down the back of the motor under/around where the turbos sit. Or...oil spatter on the underside of the hood where the turbos would sit with the hood closed.
You're using the correct Motorcraft filter...and I doubt it clogged up that quickly anyhow. Mainly the black smoke wouldn't be explained by a clogged air filter...sounds more like a turbo issue. Hopefully I'm wrong and fritz or someone will chime in.
Old 07-07-2017, 03:22 PM
AVE8R's Avatar
AVE8R
AVE8R is offline
*** SOLVED *** - 2010 F-350 6.4L DRW King Ranch making whistling noise during acceleration
Discovered small hole in the neoprene hose that connects the to the turbo.
Replaced neoprene hose. Sound is gone, smoke stopped on acceleration.
Originally Posted by AVE8R View Post
Hi Folks:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Thanks
Dave
Old 07-07-2017, 04:22 PM
DieselDenny
DieselDenny is offline
DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.DieselDenny has a great reputation on FTE.
Thanks bro, I'll inspect. Cool that some posters actually get back to the glory hole when they find the issue they put they're suit on and jumped in in the first place!!
Hat's off to you, great find!
Denny
Old 07-07-2017, 08:08 PM
AVE8R's Avatar
AVE8R
AVE8R is offline
Posting Update
Denny
Thank you sir.
I was incomplete in my posting. Yes, I believe that if someone posts a problem looking for help, it is important to share the solution once discovered, however I did not discover the problem. That credit belongs to Rick at Camden Diesel.
We have a very honest shop here in southern Georgia - Camden Diesel in Brunswick, GA. The owner is Rick. When I canít figure it out, they always do, and they are always fair and reasonable on price.
Dave
Old 07-10-2017, 09:43 AM
Picton's Avatar
Picton
Picton is offline
Glad you got it worked out Dave. A bad hose is a hell of a lot better news than a turbo issue. Thanks for the follow up.
Old 07-11-2017, 07:41 AM
AVE8R's Avatar
AVE8R
AVE8R is offline
Yes sir, and a lot less costly. Had me a little concerned...
Becky Borders
01-01-2018 07:50 PM
Becky Borders
1999 to 2016 Super Duty
01-01-2018 09:21 AM
jbonnet
12-10-2017 08:30 AM
toyomatt84
Vehicles for Sale
07-19-2016 12:25 AM
PJ-Hunter
04-11-2016 10:52 AM
Quick Reply: 2010 F-350 6.4L DRW King Ranch making whistling noise during acceleration
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
