Daily driver / project truck 1999 F450 permagrin in process used injector install
#31
edit added some comments and picture: totally agree with the rpm drop helping mpg and have the data to back it up.
From another thread but I have been meaning to ask:
The 'strain' is only detrimental if the delta between EBP and boost is high. Even then, this does not produce a rapid failure.
Ive seen stock turbos beaten with 35psi for 100k miles. There will be play in the shaft prior to catastrophic failure and you can rebuild for <$100 and sell it when you upgrade...
#32
Really appreciate your suggestions since the vast majority of information is about automatic trucks and the zf6 shifting will affect how the turbo acts.
#33
I was looking for a set but ended up swapping the 4.88 gears for 4.10 since I had it apart for my locker. Keeping my eyes open for a set of 245 with an aggressive tread. Most I see are all ribs off an RV. The rear 225 on it now are a recap that came with it. Aggressive tread and seem to wear like iron. looks like I will be "stuck" with them for a few years till they wear out some or I find a 245 with similar or better tread.
Can't wait for pictures and a review. Any clue how it is coming along?
Thanks
How much delta is high or too much? 22 boost and 25 EBP ok all day? 25 boost and 30 EBP ok for a few minutes at a time? 32 boost and 40 EBP ok for 30 seconds? I have never heard any real guidelines as how much delta is too much. Also is it the percent difference or the value?
Thanks
There is a HUGE difference between manual and auto trans. I actually put the engine from my Excursion in my 6spd truck and got back-to-back comparison with identical engine build. My X would bury 35psi boost gauge on demand and my 6spd seldom sees that much boost and obviously turbo lights completely different (much slower).
As far as exhaust housings go, you shouldnt compare AR size of one turbo to another. There is a massive amount of physics and math going on inside a turbo. So much, it's kinda laughable there are so many compressor wheel options nowadays. Just because you can draw (or attempt to copy) a wheel and have your CNC machine spit one out, doesn't mean you understand what it's doing...
I went back and forth with Charlie about .84 vs 1.0 ex housing for my KC366. He said some testers with .84 were having surge issues under some conditions ( hotter tunes I think) and talked me into 1.0 housing. Good call. That spools just fine - although under very rare conditions I could 'make' it surge a little as it spooled up. Once it was over about 30 psi the only surge was adrenaline. Did I mention that truck is FUN to drive??!!
On a stock turbo, even a tune pushes it beyond its design abilities. A bigger exhaust housing definitely helps keep EBP in check. I ran a van turbo with 160/0's in my X for awhile and that was a great combo. More power, lower EGT and lower EBP with literally no trade-offs.
We put a 1.0 ex housing on Mike K's truck (per recommendation from Brian Thompson) with stock injectors and tuned because he had surge problems. Well, Mike is still running that turbo after 3-4 years with 238/80's!!! Is it taking a beating with ridiculous EBP? Yep. Could he use more air on the top end in hotter tunes? Yep. But, that truck halls tail, will roast 35" tires at will, embarrass kids in tuner cars AND pulls the camper with no problem. I do think he rebuilt the turbo once and he checks for shaft play regularly...
#34
#35
Jason, in your experience would you recommend a .84 or 1.0 housing for the KC366 running 160/80 injectors on a ZF6 truck?
Same AR question, but for stock AD injectors on a ZF6 truck? Although, may want to bump down to the KC363 on stock injectors.
Speaking with Corey (CNC Fab) and Charlie (KC Turbo) about the KC38R they were both very adamant about the .84 housing being the right size for a ZF6 truck whether it was running stock or 160/80 injectors. As you mentioned, the difference in turbine pressure between an automatic truck and manual truck is huge.
Thoughts?
Thoughts?
#37
It is just a spreadsheet. I have it saved out on my google account and I can open it up on my phone or the computer. Here are links to a file you should be able to copy if you want. I tried opening it in Excel and the charts look bad. You need to fill in columns A B C and E for the simple one. It has formulas to do the calculation and the chart updates.
simple link
This is the same as above but also splits out towing or not towing tanks. same as above and also add a "T" to column "I" if that tank was towing.
with towing broken out
#38
#39
I think 1.0 will be the only option for the KC363/6/9 turbos. The tighter housing has caused surge in some of the beta applications. There was no problem spooling the KC369 with 238/100's.
For budget friendly, consider a van turbo (1.15 AR ex housing). With smaller injectors (Stage 1-2) a stock compressor wheel is fine. For small hybrids, an upgraded comp wheel should show some improvement.
I'm a big fan of hybrid injectors. 238/80's will do everything a set of AC (160/0's) will do with less ICP (better atomization), and lower EGT. The S369sxe was PERFECT with 238/80's in 6spd truck. This is what I'm going to do in my truck but with KC369 and 1.0 housing.
Wastegate depends on injectors and ultimately EBP. More 'boost' doesn't directly hurt even if it's out of turbo map - but EBP kills.
#41
I agree that EBP kills, but when spinning a compressor out of its map, the extra boost is a result of heat at the expense of air density. The point of a wastegate is to keep the turbo in its map as well as reducing EBP.
#42
I was thinking of taking my spare stock .84 ex housing opening up the hole and making a larger flap. It would then spool up quick like normal then allow a little more exhaust to bypass the turbine allowing lower ebp and less egt????
Also I remember seeing a post about drilling the divider so exhaust could cross over when the wastegate is open. other than that 1 person has this been looked at?
edit found it:
https://www.ford-trucks.com/forums/1...ght-now-2.html
#43
Quotes from another thread. Can that one be merged into this one by someone for me please?
going to run it like this a little bit then pull it back off and make the factory wastegate opening bigger on the Banks 1.0 housing.
Need to get a boost gauge since I may exceed what my tablet can see......
Turbo surgery. Snapped one bolt off in the old exhaust housing glad I am not using it. Had to drill out the wastegate rod eye. It would not fit the banks 1.0 housing. I also drilled a 1/2" hole in the divider to help equalize pressure when the wastegate is open.
Installed the Riffraff plenum inserts and tbolt clamps.
Map sensor stopped at 25 Something minus 14 something baro. So about 40 absolute. I thought it went higher before but that is what I saw. No leaks. Just realized I didn't hook up the ccv back up. Need to do that tonight
#44
#45
Towed the Toyhauler to set it up for camping next weekend. Very happy with the 1.0 exhaust housing. Truck seemed to have more power up top and more usable power in general.
I feel that this is due to reduced back pressure / better drive ratio. I actually saw higher boost than ebp a few times. 15 boost 14 ebp. Was only momentary possibly due to wastegate opening and closing???
No lag issues for me. I was not beating on it. Rolling the Throttle on after each shift not just slamming it to the floor. VERY HAPPY !!! Well for now at least that new KC 38R 366 or the T4 Borg Warner s366 sure are really pretty....
