89 F150 XLT Lariat- going to manual Warn hubs after factory auto hub cracked under pressure. Warn calls for the latter part, but it appears that the Dana kit will work. Any input would be greatly appreciated!
Any of them should work. As far as I know the "conversion kit" is just the normal parts you'd find in a manual hub anyway so even just buying the OEM parts for a manual hub should do it. My conversion kit only contained two lock rings and two nuts... just like factory.
