Running Power Cables to My Utility Bed
I need to run two power cables from my driver's side battery (pos & neg) to my enclosed utility bed to power a HF 12,000 lbs winch. I plan on leading the wire down from the battery through an oval in the frame rail forward of the strut and then along the inside of the frame rail and up into the bed from the rail rear of the cab.
Please let let me know if you foresee a problem with this routing.
on
Deep cycle battery?
Have you considered mounting a group 31 deep cycle battery to run the winch, then use an isolator to run a charging line to it and to support alternator-assisted charge for the winch?
Would be much easier on your starting batteries and deep cycles can go to 50% repeatedly without harm, whereas your starting batteries can only go to 80% before you start killing their life.
Batteries are cheap.
Second major benefit is very short heavy cables from new battery to winch. Less heat, less loss
I would think you would keep the motor running when running the winch and if you have the high idle feature even better, that and having a 140 amp or so alt.
just sayin,
PS harbor freight has the 12,000 lb winch on sale, or at least in the catalog I got today, for $289. That is a hell of a deal..
just sayin,
Winch Circuit Breaker Connection
Always have engine running while using the winch.
My winch is mounted on front of my gooseneck trailer. Quite a few guys have approached me admiring the set up.
The only failure I have had are when a solenoid goes bad...it happens.
My winch uses old style ford solenoids, available everywhere.
Also, wire the control so that a standard, 3 wire drop cord can be used as an extender.
Simple, yet effective...allows me to walk with my prize as I monitor loading.
