Replacing Tub/Shower Faucet?
Received 6,671 Likes
on
In the photo below the picture is NOT upside down. My faucet it upside down - note the drip. I removed the tub nozzle because it was pointing straight UP. The prior owner left it that way.
I need to know how to remove the assembly it from the wall so I can flip it over so the hot faucet is on the correct side - or at least swap handles. Unfortunately, I suspect that the faucet was left this way because the outlet for the shower hose would have hit the bulge above the faucet.
I'm making this up as I go, I'm not sure what to do. Do I need a completely different faucet?
on
I don't believe it came that way new. The prior owner acknowledged that he put it in after ordering one that didn't fit right. One of the problems I have is that I don't know what was originally there so I can't tell what the right one is to order.
Yesterday I quickly checked for access to the back of the faucet and I don't think I found it.
Curious if you have a wider picture. Wondering what the bump out above the fixture is for?
Since there is no access to the fittings, I'm wondering if you pop off the caps on the top of the handles, remove the set screws and handles and maybe the lower trim cover will lift off to reveal what's going on underneath. The fitting for the shower feed is threaded and will accept an Allen wrench if that needs to be removed to lift the trim.
I'm wondering if the PO didn't just glue and screw it to the wall since he mentioned fitment issues?
on
Jim, So we're on the same page the hot water is on the left but has the cold handle on it and the cold water on the right with the hot handle on it because the PO flipping of the faucet for clearance issues with the object above? Correct?
Does your shower area actually have a tub so there would be a faucet need? If it is just a shower floor area with no high rise area like a tub then you just need to get a shower head fixture similar to this White Two Handle Shower Valve with Vacuum Breaker
so the hose connects to the bottom.
As far as taking it of you should be able to pry/ pop op off the H/ C covers on the ***** and unscrew the ***** off, the square cover should come off and you'll see where the connection is. Pretty straight foward after the cover is off.
on
I think you nailed it. The clearance with the object above is why the prior owner flipped the fixture. It does have a tub, not that you would use the tub except for a child, so I think I still need to keep the tub nozzle.
I was thinking of adding a 90° bend fitting to the outlet for the shower hose. That way it doesn't get pinched trying to make that turn (which it is doing now). This assumes that I can swap the handle covers and also get the tub nozzle to turn 180° so it isn't pointing straight up.
Here is a picture of the faucet with the bump on the wall. My wife took this picture (bless her heart). I think she took pictures of everything just so she can keep track of when I'm "upgrading" things.
on
The outlet from the faucet to the shower hose will probably hit the part of the shower wall above the faucet.
on
That wouldn't surprise me if it needed caulk. The tub/shower hasn't been used yet and it's kind of far down on my list to make it 100% usable. But the upside down tub nozzle bothers me.
on
