3 Starter Relays Later...
Okay guys I am having some trouble getting my F6 started. It is my first attempt to get one of these trucks started. This truck is 6v positive ground. That being said the title explains it all. I have read through a lot of the previous threads on here and have gotten some great tips. I have new battery cables (2/0 gauge, too thick?), cleaned all the surfaces for proper grounds, new battery, new wiring harness, and after three starter relays I've ruined I am starting to question what I am doing wrong. I do not have spark but I want to tackle this starter issue first. Any idea what gives?
-Sam
-Sam
Where are you getting the relays from? Lots of junk out there. NOS electrical parts are better made with better materials and don't cost any more, there's little demand for 6 volt solenoids these days. Check current draw of starter off the truck, RPM, and voltage drop of starter circuits when cranking. Just some ideas. Let us know what you find!
When I hit the starter button the relay just clicks. Also a few times the motor continues to turn over after I stop hitting the starter button.
I think it would also be worth mentioning my cables get very hot where they are connected to the starter relay.
Sam
Before you try the latest version, I would recheck my wiring against the stock diagram (I'm assuming a stock truck ). Something isn't right if the starter both doesn't engage and doesn't disengage properly. The cables getting warm is also troubling. Not sure if that is after extended cranking.
If you're running 2/0 cables and they're still getting hot and you're having issues with burnt and/or welded relay contacts, I would say that your starter may well be pulling too much current. Possibly a shorted winding or a short to ground. Do you have any sort of auto electric shop in your area that you can have check it out off the truck?
