Valve Spring Height
Valve Spring Height
I have bought a new cam and valve springs matched by Comp Cam. The installed height is supposed to be 1.80". I am all over the board on my spring heights but am afraid on a couple of valves that I may not be able to shim up high enough without covering up the spring locator (bad idea). Has anyone ever used a variable height valve stem lock? Reading that they can give you + or - .050 installed height which would make the rest my project a snap. I would only need this help on 4 springs where my current installed height is 1.885, 1.880, 1.895 and 1.885.
IIRC the installed height on an fe with 1.73 ration is 1.82. I also would be more concerned running the spring below he specs because you could collapse it. But still, having springs with diff heights is little out of spec. Your lift is not big enough to cause a major concern but check your seats - they might be collapsing. Btw, are you using new valves?
No, the valves had been replaced when I got them 3.5yrs ago and had hardened seats and some intakes replaced as well. I also have a set of 1968 heads and they are off almost exactly the same way, I just figured that was the way it was with stock heads. I was running a cam of almost same lift of intake with stock springs set up at 1.82. I felt it would float at higher rpm's the springs I got with that cam were too stiff to use so just put up with it. Wanted to make sure I did this right. Supposedly, Crane doesn't recommend these locks with stock retainers but they fit better than the others I was using. They are 7 degree and will accept 3/8" valve stems.....I only used them on springs that were to tall to shim imho.
I would change those old valves. You dont know who where or what they are. $70 gets you stock 390 valves. Depending on your build.
Cheers.
Am I wrong in thinking that if you lap a valve in the seat it is going to extend that valve tip on the spring side? We are talking thousandth's in the measurement department. I just don't see how anyone can expect to have same spring height (w/o shims etc), on heads that are nearly 50 years old???
Leave the mix and match for the NASCAR boys.
The valve stems can be trimmed to match (final installed height). Of course this will require more absolute shimming to arrive @ the correct spring height/pressure and must measure for any possible coil bind.
Or you can install all new seats. It depends on how fast you want to go and how much money you have.
lovethosefords
04-24-2018 11:26 AM
MikePacey
03-01-2013 11:01 PM
SIXD9R
10-06-2008 03:58 PM
76 F150 Ranger XLT
08-26-2004 07:23 AM
FEina52F1
02-04-2002 05:17 PM
