Power Steering Pump Whine
I have had three new reman'd pumps on my 1979 F150 4x4 truck with a 460 with air conditioning and all three whine when turning the steering wheel. I am running 33x12.50-15 sized tires on my truck. I am tired of playing the game of swapping to another reman'd pump when new is not available.
I have heard you can swap out a Saginaw pump/brackets setup from a similar year Ford van with a 460 and air conditioning. I have found a 79 ford van to pull the setup out of. Would the Saginaw power steering pump/brackets also work out of a 78 Lincoln that has a 460 and air conditioning?
Number Dummy,
Would the 1978 Lincoln power steering bracket/pump be the same as the Econoline van power steering bracket/pump if they are both 460s and have AC? I ask before the brackets/pump is already off the Lincoln but would have to take them off the van. I assume the pumps are readily available to swap a new one in place?
460: 1968/78 Lincoln Continental Mark III/IV/V / 1972/76 Thunderbird / 1973/76 F100 / 1973/78 misc. Ford/Merc Passenger Cars / 1973/79 F250/350.
1975/79 F150 / 1975/97 E250/350 / 1983/97 F250/350 / 1988/97 F(Super Duty).
Saginaw P/S pump: 1972/79 FoMoCo V8 Passenger Cars with Hydro-Boost / 1975/97 Econoline.
Ford/Thompson "pencil neck" P/S pump (has a steel reservoir): 1967/77 all except with Saginaw pump.
Ford C-II P/S pump (has a plastic reservoir): 1978/79 all except with Saginaw pump.
Re
Doing some research on this topic and just saw a similar post from numberdummy from 2009. Now that is dedication to the hobby.
dis not find the answer I was looking for so will post it here.
See lots of posts on doing a Saginaw PS pump conversion, but what is easiest way to visually identify if your Engine already has a Saginaw pump conversion.
tks
tks
My experience, FWIW, I had light whine after swapping my Ford pump for a same style NAPA reman for a few hundred miles then quiet. Still quiet after ~5 years. I think it was tiny air bubbles caused by the swap working themselves out. I did need to top up the fluid initially and since then, no change at all.
I think the Ford style pump is fine as applied by the factory... though the Saginaw is probably better.
eagle275
25
05-27-2015 10:48 AM
68bronco79crewcab
08-10-2009 12:02 PM
Rocking M
08-06-2002 11:24 PM
Trail_Rider
04-23-2000 09:48 PM
400HP794x4
04-23-2000 09:41 PM
