AC engine over heats
As mentioned, you need the shroud.
Also, if you're changing t-stat, I HIGHLY advise going with Motorcraft t-stat. It's only a couple bucks more and it's OEM, 192°F.
If you're opting for a lower degree t-stat, then buy a Mishimoto 180°F.
Both are high quality and are known to perform for years. Anything from the parts store is junk. And Stant is junk.
The same goes for the radiator cap. I only replace with Motorcraft. Stant is junk!
Always check the t-stat by boiling it in water and make sure it opens and closes.
Stay away from Junk Fail-Safe t-stat's.
I may be preaching OEM Motorcraft for the cooling system, but I always do and the same goes for ignition.
These two systems work the best when using quality Motorcraft parts.
I dealt with enough of those problems on many Ford trucks and it always comes down to quality or quantity.
You can either fix it Right now or the Right WAY.
There is 95% of your problem. I would not bother with taking out the thermostat. Get a fan shroud before replacing anything else.
They were designed for a reason. No fan shroud is like taking the tires off the rims then going for a drive then complaining the ride is rough and there is a lot of noise. Not to mention it drives terrible in the rain.
Also, don't put Chinese junk on there since it is such a critical part if you can afford not to, although more and more Motorcraft parts I buy seem to be made there sooo... SHM
For example, I had a 29 gallon air compressor from Harbor Freight. Pump, motor, tank all made in China. Would you believe it was the quietest and smoothest running twin cylinder single stage I have ever heard? The motor was Chinese, the pump appeared to be an IMC (or was it a clone?), but there was no casting flash, no appreciable amount of metal shavings in the oil after the initial break-in, none of the crap you normally see with China garbage. It ran great til I sold it for a 60 gallon two stage.
Motorcraft I'm sure has stringent QC standards for their parts and they wouldn't allow bottom of the barrel, run of the mill China garbage to be sold with their name on it. So just cause it's made in China don't mean it's automatically garbage. It's only as good or bad as the company that awards the contract to the Chinese factory allows it to be.
Now, all that being said: I still prefer to BUY AMERICAN when possible!
To the OP: I'm in Florida too. Get a fan shroud on that thing and install a 180 degree thermostat. As mentioned before, stay away from the "fail-safe" thermostats! I've run 180 degree 'stats for years. Go with Motorcraft brand, anything from the parts store is a crapshoot! You'll still have plenty of heat for the mild winter we have here, but your engine and cooling system components will thank you during the summer!
My solution is either going to be full electric fan or helper electric fan haven't decided for sure yet. For now I just turn the ac off if im stuck idling in a drive thru. (update advanced my timing some and has seemed to help )
