My first write-up and story! TSB 98-4-8 - Page 2 - Ford Truck Enthusiasts Forums
Old 01-21-2019, 06:51 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Da_Lariat_Chariot is offline
Da_Lariat_Chariot is gaining momentum as a positive member of FTE.
Originally Posted by JHaritos View Post
I know this thread is a little old but I'm taking a long shot here. Do you happen to remember what the Ford part number is for the heater control valve? If not, then what vehicle is it off of?
Thanks
I can get you a Murray part number later but the valve is from a 2010 Ford Ranger.
Old 01-21-2019, 10:52 PM
JHaritos's Avatar
JHaritos
JHaritos is offline
JHaritos is starting off with a positive reputation.
Part Numbers For The R-134a Switches
Just in case someone does a search later to get some info on part numbers...
Motorcraft YH 552 is the R-134a Clutch Cycling Switch
Motorcraft YH 1705 is the R-134a High Side Cut Out Switch/WOT Cut-Out Switch
Motorcraft YG 350 is the Ford Ranger Heater Control Valve
There is also a connector you will have to buy for the high side switch. I couldn't find a part number but the description for it on amazon.com is "Ford A/C Cycling Pressure Switch Harness Connector".
axelfoxx
07-27-2017 06:20 PM
1996_5.8
03-15-2017 11:11 AM
UNTAMND
09-28-2016 11:18 PM
kr98664
34
08-14-2016 05:41 PM
bf5113x
21
05-24-2016 05:00 PM
Quick Reply: My first write-up and story! TSB 98-4-8
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
