2002 F250 transmission cooler line fittings in radiator
I am replacing transmission cooler lines to radiator, and I need to change out the fittings in the radiator that the tubes screw into. These are flare/nut fittings.
The originals are very rusty..
Do these fittings "typically" just wrench out, or more to it.?
I've attached the "as-is", and "what should be.
Thanks for your inputs.
Dan
Dan
TRANSMISSION 3/8" COOLER LINE REPAIR FITTING, FORD RADIATOR
Found this ad awhile ago, they might have some useful info.
I'll look into it.
Dan
afonda
50
09-09-2023 08:07 AM
bellinoracing
2004 - 2008 F150
52
09-10-2019 11:26 PM
riderre1997
07-03-2015 04:41 PM
