Measurement Request: 4x4 Dana 44 Bracket
Thanks Gary!
All the front end suspension parts were removed from the old frame and transferred over. I did have new rubber bushings installed. Before the frame swap the wheels had a neutral camber. Now they have a negative camber with a toe-out.
I'm asking because when I get the truck on the road I want to be able to get the alignment correct, and get the correct parts. I was never sure of what suspension parts were on the front. I assume it's a 2 inch suspension lift. But I want to know for sure.
It's a long winded explanation but it's an odd situation.
Based on "how level/parallel" your steering linage is - I'd say you will have no problems with alignment. Whatever drop bracket is installed looks to be correct for your spring setup. Steering Tech - An in-depth discussion about TTB Steering and Alignment
Thanks reamer. Looks like I'll be finding 2 inch springs as well.
