2011 F350 XLT volume quit working - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 06-19-2017, 07:44 PM
dpilot83 dpilot83 is offline
dpilot83 is starting off with a positive reputation.
I can not hear the radio in my 2011 F350 XLT. I don't know what radio options there were for the XLT but mine has a Sync USB port, Bluetooth, steering wheel controls, CD player but it does not have a big display or touchscreen or anything like that.
When I try to adjust the volume with either the steering wheel or the radio dial, the indicator shows the volume is at half but the volume will not go up or down. I can hear nothing. All other buttons appear to work.
Have Inaccidentally gotten into some more that doesn't allow it to play any sound or adjust volume or is something just flat out wrong?
Thanks
Old 06-19-2017, 08:19 PM
seville009 seville009 is offline
seville009 is starting off with a positive reputation.
You sure it's set on "radio" and not a different source? Make sure nothing's plugged into the usb port (that it might be trying to read).
A simple reset would be to unplug the battery for a few minutes to see if that does the trick.
Old 06-19-2017, 08:24 PM
Thanks. I have tried AM, FM 1, FM 2 and AUX. Volume controls have no effect in any of those. I do not have the USB plugged in. Same for the audio jack (never used either of them that I remember actually).
I will try unhooking the battery overnight when I get in tonight.
Old 06-20-2017, 08:58 AM
I should also emphasize that I believe the volume controls are working because when I attempt to adjust volume the volume level display pops up on the display, it just doesn't change.
Old 06-20-2017, 08:59 AM
Forgot to unhook battery last night. Will try to do that sometime today.
Ford F150 radio problems judge26 2009 - 2014 F150 1 10-03-2017 04:03 PM
Problems with factory radio... Lebowskii 2009 - 2014 F150 5 01-11-2017 06:59 PM
Phone ringer volume down and voice volume up sixseven 2015+ F150 4 08-04-2016 11:26 AM
2011/2012 f250/f350 nav radio problems Tbrogreene 1999 to 2016 Super Duty 0 05-28-2016 05:25 PM
Speed Sensitive Volume Control pikapp 2015+ F150 4 12-23-2015 04:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
