need confirmation of the location of the anti drainback valve - Ford Truck Enthusiasts Forums
Old 06-19-2017, 04:27 PM
dp1181 dp1181 is offline
dp1181 is starting off with a positive reputation.
I am amazed that there is very little about this, symptoms cold starts getting longer, oil pressure on gauge in sync with the long starts.
Ive found some discussion but it degenerates to problems with hpop and hoses. this problem is a low pressure problem and yes the hpop reservoir is draining back. even before id heard of the "anti drainback valve" I KNEW THERE WOULD BE A CHECK VALVE IN THE SYSTEM SOMEWHERE. So, can anyone confirm that the antidrainback valve is in the oil filter housing and give me a part number? theyre easy to find for the 6.0 but not so much for the 7.3. you have my appreciation!
Old 06-19-2017, 04:35 PM
AllaboutMPG's Avatar
AllaboutMPG AllaboutMPG is offline
AllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to beholdAllaboutMPG is a splendid one to behold
some info and pics in the following thread. mostly on page 2
https://www.ford-trucks.com/forums/1...ir-plug-2.html
Old 06-19-2017, 04:48 PM
Whitey Ford's Avatar
Whitey Ford Whitey Ford is offline
FTE-Spread The Knowledge
Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.Whitey Ford has a great reputation on FTE.
Old 06-19-2017, 04:53 PM
thanks, it makes sense that the upper check valve could cause leaking and its the easiest to fix. This doesnt appear to be that common a problem but i will post my results.
Thanks again
Old 06-19-2017, 05:09 PM
The way I understand it that is not really a drain check valve but more of a pressure relief for the oil cooler. If there were a piece of dirt under the ball I guess it could drain the hpop res down but only as far as the standpipe. Not sure how far that is, will need someone with more knowledge of the hpop to come along.
Have you ever changed or cleaned the IPR?
Old 06-19-2017, 05:17 PM
Old 06-19-2017, 05:43 PM
well i'll be! thanks allaboutmpg, this is something i will be looking for.
Old 06-19-2017, 08:16 PM
F350-6's Avatar
F350-6 F350-6 is online now
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
It's still almost never the check valve. Keep an open mind and good luck in your search.
Old 06-19-2017, 08:32 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
Bad upper injector o-rings can also cause the reservoir to drain.
Old 06-22-2017, 02:26 PM
as is always the case, where would the oil go if orings were bad and how could you test?in the case of upper orings the oil would go right back into the crankcase wouldnt it?
Old 06-23-2017, 03:53 PM
Pikachu's Avatar
Yes, bad upper o-rings would let the oil simply drain back into the crankcase. You can pull the valve covers and look for leaks with the engine running, or you can pressurize the oil gallery in each head with compressed air and listen for the leak once the oil has been forced out.
Oil Drainback valve Part #.. Housing has no oil after overnight sit...?? ol-blu 6.0L Power Stroke Diesel 25 09-11-2017 01:38 PM
HPOP advice Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-10-2017 11:12 AM
Possible LPOP Failure--BOPAS BBslider001 1994.5 - 1997 7.3L Power Stroke Diesel 27 03-03-2017 11:08 PM
Advice for starting resealed engine Bubba Jones 1994.5 - 1997 7.3L Power Stroke Diesel 16 04-23-2016 12:24 AM
HPOP O-rings or check ball or........ Desert Storm Vet 6.0L Power Stroke Diesel 6 03-01-2016 03:01 PM
Tags
7.3, antidrainback valve, hard to start, long cranks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
