Need 4" exhaust replacement pipe over rear axel for excursion
Good morning. I noticed yesterday the the 4" exhaust pipe where it goes over the rear axle is rusted out. Is it possible to get just that section from after the muffler to the tip? Thank you.
I wanted to yesterday but didn't have any luck finding the number. I'll look again later. I called Clay at riffraff and he said it would probably be a special order but wanted the kit number of the original which I don't have anymore. I would think that section would be the same for a lot of kits. The economy kits are on the $260 range so if I have to I'll do that. Hopefully less than $50 if I can get it
