Want to add bed lights - Ford Truck Enthusiasts Forums
2017 Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-19-2017, 12:16 PM
spongecop's Avatar
spongecop spongecop is offline
Semper Fi
spongecop is gaining momentum as a positive member of FTE.
My truck did not come with the LED bed lights. I cannot find a kit or part number online to add them. Does anyone know what the part number is? IS it the same as the F150?
Thanks,
Old 06-19-2017, 12:26 PM
duckduke duckduke is online now
duckduke is starting off with a positive reputation.
Quote:
Originally Posted by bushpilot View Post
sounds like you'll be installing some of these....
https://www.gorecon.com/product/835/...-BED-LIGHT-KIT
May want to try this
Old 06-19-2017, 12:46 PM
Sparks123 Sparks123 is offline
Sparks123 is starting off with a positive reputation.
Quote:
Dont think those will work seeing as there is no cabling to hook it up to at the moment. I think OP is asking if the F150 kit with cabling will work on the Superduty
Old 06-19-2017, 12:49 PM
spongecop's Avatar
Semper Fi
Quote:
That is correct
Old 06-19-2017, 06:54 PM
Tricon's Avatar
Tricon Tricon is online now
Tricon is gaining momentum as a positive member of FTE.
This is for the F150, not sure if it would work in ours.
Amazon Amazon
To be honest though, I think you would be better off buying the recons and then just wiring them up yourself. Put a switch back there in the tailgate and make your positive run to the battery in the front. Sounds like thats cheaper, easier, and a better light unit.
Bed Lights BADAS03SVT 2017 Super Duty 33 06-06-2017 06:44 AM
LED Bed Lights Dumb Question Chevmn56 2017 Super Duty 6 04-27-2017 10:03 PM
OEM trailer harness for inside the box? Baatzy 1999 to 2016 Super Duty 9 03-23-2017 07:41 PM
Part number Bed light switch AWandKW 2015+ F150 0 02-13-2017 10:13 AM
In bed LED lights k4owb 2017 Super Duty 2 09-11-2016 11:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
