Replacing 223 Intake/Exhaust Manifold Gaskets - Page 3 - Ford Truck Enthusiasts Forums
Old 08-07-2017, 06:08 PM
Wolfracing
Wolfracing is offline
Wolfracing is gaining momentum as a positive member of FTE.Wolfracing is gaining momentum as a positive member of FTE.
OK I am eliminating things. I thought it ran a LITTLE better with the coil off another truck. But still bad. But it was good enough to run for some diagnosis.
I can find a place with the choke mostly closed that it runs pretty good. Even with the truck reved up, it needs a good amount of choke, but will run. So either it really doesn't have enough coming from the fuel pump, or there is something about the carb messing with me. I rebuilt it, so it's entirely possible that it was rebuilt wrong somehow. So now I can focus on fuel, which ironically is where I started.
  #32
Old 08-07-2017, 06:11 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
It's the new condensers that cause trouble these days, they are usually defective from the git go. Very common issue. Try an old one out of the junkbox.
  #33
Old 08-08-2017, 10:57 AM
DriverReturnedOnFoot's Avatar
DriverReturnedOnFoot is offline
DriverReturnedOnFoot is starting off with a positive reputation.
Glad to hear you've narrowed it down!
  #34
Old 08-13-2017, 11:18 AM
Wolfracing
Ok it is the carb or at least that is part of the problem. I knew after spraying that there was some amount of leak around the carb shaft. Taking it apart revealed that the shaft is very worn in one spot and the carb itself is very worn all the way around. I know there are bushing kits, but man there isn't very much material to work with on this one. So by the time I throw a shaft and bushing at this, and new gaskets, I will have at least another $65 into it with shipping.
So I am pausing on that plan. A new/rebuilt carb is sounding better and better. I have another engine from a different year with a Holley on it, but then I have to address the spark advance deal.
So my question is, stay the course with an Autolite 1100 or is there a better performing and reliable alternative I should be considering? Is there a preferred place that sells the rebuilt carb less expensive than others?
  #35
Old 08-13-2017, 12:33 PM
Wolfracing
I am not opposed to ditching the LOM style distributer, and even uprgrading whatever I get with electronics.
iron1951
09-06-2017 05:14 PM
Deanp88
6.4L Power Stroke Diesel
02-08-2017 10:13 PM
JF492
02-05-2017 06:10 PM
bdavis1369
1999 to 2016 Super Duty
10-09-2016 04:51 PM
HiZ
Modular V10 (6.8l)
05-27-2016 09:08 PM
Quick Reply: Replacing 223 Intake/Exhaust Manifold Gaskets
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
