Black primer on new body panels remove or keep? - Ford Truck Enthusiasts Forums
Old 06-19-2017, 09:23 AM
Jules The Great
Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
Morning guys,
I did some specific searches but did not find a thread asking about the black primer that comes on some of the body panels. I removed it everywhere I had to weld. Do you guys remove all the black primer or leave it? Does anyone know what kind of primer it is? I read somewhere it was epoxy but find that hard to believe.
Old 06-19-2017, 09:32 AM
drptop70ss's Avatar
drptop70ss
drptop70ss is online now
drptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud ofdrptop70ss has much to be proud of
Wipe it with reducer, if it comes off it is just cheap black primer to prevent rust. If it stays on it should be good to scuff and shoot.
Old 06-19-2017, 05:14 PM
EBEAR's Avatar
EBEAR
EBEAR is online now
EBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to beholdEBEAR is a splendid one to behold
I have never found the primer supplied on new pieces of very good quality . I would remove it then you know your base is the same everywhere . Just my 2c .
Old 06-19-2017, 06:32 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is online now
CharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant futureCharlieLed has a brilliant future
There are fairly decent e-coatings on quality panels and there are any number of spray coatings that "look" like e-coat but are only good for keeping flash rust off the panel. As a rule of thumb, I sand the black coating down to the metal in one area of the panel...if the coating feathers out then the adhesion is good. If the coating goes from black to silver immediately then the coating is flaking and should be removed.
Old 06-20-2017, 11:08 AM
petemcl's Avatar
petemcl
petemcl is online now
Still Learnin'
petemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud ofpetemcl has much to be proud of
The new front panel for my truck bed came with good primer on it.
Truck bed front panel
It looked like black ecoat powder was used but not sure as acetone did not touch it and it was flawless. I did rough up the surface with 400 grit before painting it.
turnrjr
13
10-06-2017 08:25 PM
Russ74
02-06-2017 05:53 AM
filthy6
06-04-2016 12:44 PM
macs40
Paint & Bodywork
06-03-2016 02:16 PM
cgrutt
2004 - 2008 F150
03-02-2016 12:38 PM
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
