Weird Shake at Idle After Service - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 06-18-2017, 10:36 PM
akblackfoot's Avatar
akblackfoot akblackfoot is offline
akblackfoot is gaining momentum as a positive member of FTE.
We had a main bearing seal and some transfer case seals replaced that required removal of the transmission. Got it back and the wife drove it home. First time I got in it I noticed that while at idle in park or neurltral it shakes. The shake goes on and off in about 2 second intervals. Feels like something out of balance. At speed it rides smooth with no shake. Shifts fine and no problems. What could cause this?
Old 06-19-2017, 07:27 AM
Skauber Skauber is offline
Skauber is gaining momentum as a positive member of FTE.
My first thought might be a misfire, perhaps the mechanic didn't plug an injector or COP in properly, or even swapped the connectors between two cylinders.
Old 06-21-2017, 06:01 PM
No codes come up. Vehicle runs smooth and it doesn't feel like a miss. Could it be some kind of balance issue with the torque converter or something else when they put the transmission back in? They can't figure it out.
Old 06-22-2017, 03:28 AM
Not unless they dropped the converter when putting it in.. But that would be a constant shake, not coming and going. If it's a constant rhythm to the shake, it might be mechanical. As it sounds like it's even when you're not moving, then anything after transmission can be ruled out.
You said it comes and goes with intervals of about 2 seconds, is this constant? Does it change with engine speed?
Old 06-22-2017, 11:25 AM
alloro alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Quote:
Did you called the shop that did the work and report it to them yet? Maybe they've had this happen before and already know the answer.
Old 06-22-2017, 01:36 PM
They had it for two days trying to figure it out and took it to another tranny guy for a second opinion. It goes away at about 1500-2000 rpm or when you put it in gear at any rpm. It only shakes in park or neutral. It shakes constant for two seconds, smooth for 2 seconds, shakes for 2, etc. It seemed to smooth out after about 15 minutes of idling but comes right back if I drive it again. When driving everything is smooth and even parked in gear it's smooth.
Old 06-22-2017, 02:12 PM
There's not really a whole lot going on in the transmission when it's in neutral/park. The converter is rotating, which drives the oil pump and the input shaft, and that's about it. Though Mark could probably tell a lot more about this, I don't think any of the planetary gears are rotating at all when it's in neutral
Off Topic - Wierd Shake akblackfoot 6.0L Power Stroke Diesel 1 06-23-2017 11:46 PM
Shaking in idle and accelleration. Help Jack Perez 1999 to 2016 Super Duty 4 05-26-2017 05:54 AM
Idle shake xtamer Ranger & B-Series 3 01-16-2017 11:24 AM
P0284 code bowranger 1999 - 2003 7.3L Power Stroke Diesel 2 03-26-2016 10:54 AM
89 f250 351w shakes at idle paintslinga2010 1987 - 1996 F150 & Larger F-Series Trucks 7 12-15-2015 10:10 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
