finally gettin' at my '95 F250 4x4...been sitting about 2.5 years...drained fuel bowl and filled with fresh diesel...ran ok for about 2 blocks then died...water inn fuel lamp is on...is this sensor accurate, if so, best way to solve this...drain tank and refill...or is there a better easier way...I miss this stinky ol' beast
Thanks Mike...I purchased a hand pump syphon...figured this was easier on my ol' crippled back...I'll syphon both tanks and get enough fuel to get me to town, then top tanks up...will the syphon get enough out so fresh fuel won't be affected????
it looks clean...but at 2.5-3 yrs old the water in fuel lite comes on and the truck stalls...I did drain fuel bowl and topped with new fuel...fired right up...until it started trying to run on the fuel in the tank....thanks!!!!
well...fresh fuel and no start...tried ether and it fires then dies...would old oil have anything to do with this???...oil has about 1500 miles when I parked it...thanks folks
I've read that today's ULSD fuel has a shelf life that is much shorter than the traditonal high-sulphur variety, and when it is mixed with biofuels, the shelf lift is in months, not years.
