Shell Fuel 20 Gallon Top-Off Limit - Ford Truck Enthusiasts Forums
2017 Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Old 06-18-2017, 03:09 PM
shortride's Avatar
shortride shortride is online now
shortride is gaining momentum as a positive member of FTE.shortride is gaining momentum as a positive member of FTE.
When I had my 2015 F-150 Ecoboost Limited I wasn't concerned with the Shell 20 gallon fuel-up limit. Now with the 34 gallon Super Duty and a new Bass Tracker boat with a 30 gallon tank it's kind of a hassle to shut the pump off at the 20 gallon limit and start it over again in order to fill up. Are you folks with Shell accounts having the same issue?
Old 06-18-2017, 03:11 PM
Xwild's Avatar
Xwild Xwild is offline
Xwild is starting off with a positive reputation.
No gallon limit around here.. but there are dollar limits.. normally 50 or 75 bucks. Really sucks when I pull in with the 48 gallon tank when the low fuel light is on... takes 3 swipes of the credit card sometimes if I actually want to get filled all the way up.
Old 06-18-2017, 03:21 PM
TrikeDawg's Avatar
TrikeDawg TrikeDawg is offline
TrikeDawg is gaining momentum as a positive member of FTE.
I don't buy Shell gas or diesel because they are the highest priced fuel in my area. They are the first to raise and the last to lower their prices. Gas and diesel prices at my local Costco are .20 to .40 cents lower than the Shell station next door. Costco gas is a Top Tier gas just as Shell is and the Costco diesel is the clearest and cleanest diesel that I can buy in my area.
Old 06-18-2017, 03:28 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I run fuel at the local co-op. I have an account so I can run up to 2500 bucks if I really need too.
On the road you might consider a RV advange card with pilot/flying J. That will allow you to fill up at the truck lanes and pay the correct pricing. No fill up limit and no pre-pay either.
Old 06-18-2017, 05:29 PM
ERock62's Avatar
ERock62 ERock62 is online now
ERock62 is starting off with a positive reputation.
Had this happen at the Shell close to my work. First (and only) time filling up there I hit the cut-off.
Old 06-18-2017, 05:53 PM
Screamingbear's Avatar
Screamingbear Screamingbear is offline
Screamingbear is gaining momentum as a positive member of FTE.
Costco
I fuel up at Costco as often as I can.
My local Costco is always the lowest price in the area, without fail. Usually 5 to 10 cents cheaper than the lowest price brand name stations, and 40 cents or so cheaper than Shell.
Old 06-18-2017, 06:39 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat Paw's 150 Lariat is offline
Paw's 150 Lariat is gaining momentum as a positive member of FTE.Paw's 150 Lariat is gaining momentum as a positive member of FTE.
Pump shut off at $85 bucks on me at my local Shell station.
Old 06-18-2017, 06:42 PM
c502cid c502cid is offline
c502cid is starting off with a positive reputation.
The shell rewards card has a 20 gallon limit on discounted gasoline.
Old 06-19-2017, 06:36 AM
KubotaOrange76's Avatar
KubotaOrange76 KubotaOrange76 is offline
KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.
The shell i fill up at sometimes has a big truck pump out back that sees alot of volume, it cuts off at $125. But if i use our rewards card from work for a discount (home depot $) it limits the discount fuel to 20 gallons
Old 06-19-2017, 08:32 AM
shortride's Avatar
Quote:
I have a Shell Rewards card. Maybe that it but I can't imagine why.
Old 06-19-2017, 08:38 AM
Frantz's Avatar
Frantz Frantz is offline
Frantz is a splendid one to beholdFrantz is a splendid one to beholdFrantz is a splendid one to beholdFrantz is a splendid one to beholdFrantz is a splendid one to beholdFrantz is a splendid one to beholdFrantz is a splendid one to behold
We use a Sunoco station for lot fuel and I get over the $100 mark on diesel trucks pretty often. No issues.
Old 06-19-2017, 08:41 AM
caadoptees's Avatar
caadoptees caadoptees is offline
caadoptees is starting off with a positive reputation.
Quote:
That is the reason. During their current 5c/gal discount, they limit you to 20 gallon per transaction.
I just run again as many times as needed.
Old 06-19-2017, 09:04 AM
HRTKD's Avatar
HRTKD HRTKD is online now
HRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to beholdHRTKD is a splendid one to behold
Well, as long as we're talking Shell...
Last night, after returning from a camping trip I filled up with about 60 miles to empty (the great lie) on my 48 gallon tank. The station was completely out of gasoline, but not diesel. So I had the station to myself. That was kind of nice. I had time to wash my windows, mirror caps, bumpers, headlights and check the oil.
My local Shell station uses a $.10 / gallon discount but only up to 35 gallons. This is through King Soopers/City Market/Kroger.
Edit: My local Shell stations are fairly competitive on price without the discount. Add the discount and they beat every other station.
Old 06-19-2017, 09:09 AM
k7lvo's Avatar
k7lvo k7lvo is offline
k7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to beholdk7lvo is a splendid one to behold
How much did the tank hold with 60 mte indicated? Did you top it off? I ran mine down to 10 mte, topped it off, and it took 46.5 gallons. (A while back I also topped it off a few miles after the needle moved off of "full." It took 8 gallons!)
Old 06-19-2017, 09:48 AM
HRTKD's Avatar
I wrote it down and I'll look at it when i get home. I'm pretty sure it was just a bit over 40 gallons. I was expecting it to be higher. Apparently the reserve on the 48 gallon tank may be just as bad as on the smaller tanks.
Custom Aluminum 80 gallon Fuel Cell w/Sump BroncoDually 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 04-06-2017 09:48 PM
Shell Rotella $5 Gallon Rebate-Denied-Update Inginear 6.0L Power Stroke Diesel 0 10-15-2016 09:42 AM
Auxiliary Fuel Tank Question dieselsubmariner 1994.5 - 1997 7.3L Power Stroke Diesel 4 04-15-2016 10:00 AM
38 Gall Fuel Tank + Hitch and Spare Blue and White 1973 - 1979 F-100 & Larger F-Series Trucks 12 04-25-2015 09:20 PM
7.3 fuel problem Melendez7.3 1999 - 2003 7.3L Power Stroke Diesel 6 04-21-2015 10:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
